Old 05-26-2014, 02:46 PM   #1
maxdog51
maxdog51's Avatar
Coolant overflow tanks?
What one is a good fit for 47-54 radiator?
What coolant overflow tank are you using?
How about some pics?
Thanks,
Frank
maxdog51 is offline   Reply With Quote
Old 05-26-2014, 03:18 PM   #2
dubie
dubie's Avatar
Re: Coolant overflow tanks?
I'm using a 800ml Rockstar energy drink can mounted inside a BMX water bottle holder
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-26-2014, 03:39 PM   #3
mr48chev
mr48chev's Avatar
I used to have one of those plastic aftermarket ones from the parts house but I think this time I'll have my son weld me one up out of a piece of scrap stainless tubing. I might even use a piece of 2 inch exhaust pipe and paint it black to hide it a bit.
My ongoing truck projects:
Old 05-26-2014, 04:00 PM   #4
capnduane
capnduane's Avatar
Using the plain looking, plastic, aftermarket one. Would like to fit a cool aluminum tube one, but really like to be able to check my coolant level at a glance when I open the hood.
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder"
capnduane is offline   Reply With Quote
Old 05-26-2014, 06:08 PM   #5
joedoh
joedoh's Avatar
I am going to use the original one on the firewall, and see how it works.
Old 05-26-2014, 07:06 PM   #6
_Ogre
_Ogre's Avatar
in my 58 i have a piece of 304 stainless exhaust tube capped on the ends
3/8'' ss half couple welded in for a hose barb.
couple of tabs to screw it to the inner fender.
end caps are cut out of flattened tube.
works, holds enough
polished it and then hid it under my radiator cover
shop air compressor timer
Old 05-26-2014, 09:51 PM   #7
msaintg
msaintg's Avatar
for almost the same price as the cheap plastic ones (that don't really fit), I found this on Ebay. It worked perfect...
msaintg is offline   Reply With Quote
Old 05-26-2014, 10:54 PM   #8
BlueJeep
BlueJeep's Avatar
This is exactly why I'm going to use a plastic one. I have several, none of which fit like I'd like them to. But, I haven't made it to a pick-and-pull recently and I know that there's one out there for me!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 05-28-2014, 07:46 AM   #9
maxdog51
maxdog51's Avatar
Great suggestions!
Thanks for the pics also.
I do like the idea that a plastic one will allow me to see the level at a glance.
Old 05-29-2014, 09:26 AM   #10
YahamaR1
YahamaR1's Avatar
Got this one from BrothersTrucks.
YahamaR1 is offline   Reply With Quote
Old 05-29-2014, 10:52 AM   #11
klutz51
if you are using a aftermarket radiator like i am, and running a external trans cooler, you can use the unused trans cooler in the radiator. seen that and it looke really clean.
klutz51 is offline   Reply With Quote
Old 05-30-2014, 08:15 AM   #12
Russell Ashley
Russell Ashley's Avatar
Not sure there's room for this in an AD but here's mine. I got it at Pull-A-Part out of a Ford van for $4. It met my requirements of cheap, easy to mount, visible water level, and left room for the A/C hoses below it. Not show but then nothing else about my truck is either, LOL.
Russell Ashley is offline   Reply With Quote
Old 05-30-2014, 11:55 AM   #13
roger55
roger55's Avatar
You need an overflow tank with a crossflow radiator but why use one on a downflow at all? Just keep the water level about at an inch down from the cap. The only time it would spew water would be in an overheat situation. I'm just going to run a tube down the side and call it good.
roger55 is offline   Reply With Quote
Old 05-31-2014, 03:04 PM   #14
Lextech
Lextech's Avatar
[QUOTE=_Ogre;6693985]
Ogre, I'm not really sure that is functional. It probably has 90% air in it and acts as an expansion tank. I would think that coolant will push into it but only by the amount that the air in the tank compresses.
Jeff
Lextech is offline   Reply With Quote
Old 05-31-2014, 07:45 PM   #15
mr48chev
mr48chev's Avatar
They do have to vent to work right.
I'm going to run one simply because there is a chance that it might build up enough pressure in slow traffic like being in line to get into an event and puke and on mine that ends up coming right up through the louvers even when the hose is on it right and shoots down towards the ground.
Old 05-31-2014, 07:48 PM   #16
S10Fan
Old Heap Driver
Here's mine, and yes, it does work properly, I can see the fluid going back into the radiator as things cool off.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 05-31-2014, 11:49 PM   #17
solidaxel
solidaxel's Avatar
Those are the ones I use on my A D's.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-01-2014, 12:16 AM   #18
capnduane
capnduane's Avatar
Don't mess with my PBR..... Gotta love it!
Old 06-01-2014, 06:07 AM   #19
S10Fan
Old Heap Driver
Thanks, I have a co-worker that keeps me supplied with "Coolant Overflow Tanks". LOL
Bryan
Old 06-01-2014, 09:06 AM   #20
DransportGarage
DransportGarage's Avatar
I manufacture my own. I can make 3 or 4 a day ...
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 06-01-2014, 12:45 PM   #21
_Ogre
_Ogre's Avatar
[quote=Lextech;6700741]
Jeff
the vent tube is visible on the bottom of the tank.
13'' long tank, 16'' long vent tube.
angle cut and stuck in to the top of the tank
then bent to avoid spewing on the frame
Old 06-01-2014, 04:05 PM   #22
Stepside Jim
[quote=_Ogre;6701803]
I see it....
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132
Stepside Jim is offline   Reply With Quote
Old 06-01-2014, 04:27 PM   #23
Lextech
Lextech's Avatar
The vent tube is visible on the bottom of the tank.
Angle cut and stuck in to the top of the tank
Aahhh---Good Deal. I see it now.
Jeff
