Old 05-26-2014, 02:41 PM   #1
BoneCollector
What size exhaust pipe to run?
Hi guys
I don't post on here much, but I hope you can help me out. I just installed a set of Summit Racing headers with 3" collectors on my small block. They included a set of 3" reducers.
The question is should I stay with the 3" pipes all the way back? Or should I run 3" to a muffler that exits at 2 1/2" or 2 1/4"? I plan on running pipe to the muffler somewhere below there the cab and the box meet and exit in front of the rear tire.
What should I do? What are the pros and cons between keeping the 3" all the way back or switching to a smaller diameter pipe.
Thanks in advance.
BoneCollector is offline   Reply With Quote
Old 05-26-2014, 02:50 PM   #2
cdowns
cdowns's Avatar
Re: What size exhaust pipe to run?
the longer you run a 3" pipe the more you loose out on your torque curve of your ewngine// a 21/4 or 21/5 pipe will run much better
Old 05-26-2014, 02:52 PM   #3
70cst
70cst's Avatar
Mine was 2 1/2"
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-26-2014, 08:15 PM   #4
gvw5400
gvw5400's Avatar
2 1/2" works well for me. All the best, Dirk
gvw5400 is offline   Reply With Quote
Old 05-26-2014, 09:16 PM   #5
Norcal72
A lot has to do with the engine. Is it a fire breathing 11 to 1, 7500 rpm shift sbc? Then go with 3". If it's stock grocery getter, I would go with 2 or 2.25". If you have a mild build, headers, intake go for 2.5". Just my opinion.
Norcal72 is offline   Reply With Quote
Old 05-27-2014, 12:26 AM   #6
70blackfish
2.5 for up to 500 hp
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 05-27-2014, 12:45 AM   #7
findog78
I just got new exhaust with x-pipe and magnaflow 3XL's exiting in front of wheels. I went from 2.25" to 2.5" and lost noticable tourque. Motor is not stock but not a fire breather. If there were do-overs I would go 2.25" again. Thats my $.02
findog78 is offline   Reply With Quote
Old 05-27-2014, 09:59 AM   #8
msgdsrf
+1, too much exhaust equals too little fun to drive. Sound is different too. 3" without big air to push through sounds off too. And bigger pipes tend to add more drone in the cab. Food for thought.
msgdsrf is offline   Reply With Quote
Old 05-27-2014, 10:15 AM   #9
CC69Rat
CC69Rat's Avatar
Tell us more about your motor (?)
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 05-27-2014, 11:11 AM   #10
Stu Pidd
Headers work properly only when they have enough velocity flowing through them.
Go too big on the exhaust, and velocity slows down, eliminating the header's scavenging ability.
Stu Pidd is offline   Reply With Quote
Old 05-27-2014, 12:17 PM   #11
NONHOG
NONHOG's Avatar
Another thing to consider is as exhaust cools it needs less volume.
That's why many factory exhaust systems neck down as they go back.
Some say run as big as you can and adj. fuel accordingly. I say run what the experts call for. Plenty of charts online to help choose the proper size based on HP. And think about how often you will be at peak HP. Driver or racer?
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 05-27-2014, 12:30 PM   #12
chevy72blu
chevy72blu's Avatar
2.25" on a very mild 350 (vortec heads, cam, intake, headers) worked well for me. Caught some flack about my "pea shooter exhaust" but it pulled hard down low.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 05-27-2014, 01:16 PM   #13
Fitz
Originally Posted by BoneCollector View Post
Hi guys
Thanks in advance.
Run 2-1/2 using a reducer at the header collector.
Fitz is offline   Reply With Quote
Old 05-27-2014, 07:29 PM   #14
BoneCollector
Its just a 307 or now. I plan on building a 350 or a 383 int the future when I start to rebuild the truck.
I decided to go with 2 1/2 inch all the way back. I'm going to run some 23 inch Thrush glasspacks on it and 45 it out before the rear tire.
