Old 03-28-2014, 11:07 PM   #76
Bennett68C10
Bennett68C10's Avatar
Re: Project "la sancha" 69 SWB
Your frame looks great and nice job on the cab too.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-29-2014, 03:50 PM   #77
afmedic01
afmedic01's Avatar
Originally Posted by knomadd View Post
I like what you've done so far. I'll be following along.
Thanks Duane.
My build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=611258
69 C10 SWB Fleet(under construction)
350/TH350
Porterbuilt Front/Rear Mild Dropmembers
Accuair e-level kit
Coys C5 22x9, Nitto 555 255/30r22
afmedic01 is offline   Reply With Quote
Old 03-29-2014, 03:52 PM   #78
afmedic01
afmedic01's Avatar
Thanks Keith, wish I was as far along as you though.
My build thread:
350/TH350
Accuair e-level kit
Old 05-05-2014, 08:21 PM   #79
afmedic01
afmedic01's Avatar
Its been a while since I posted any pics. I've been really busy at work and with the family. I started doing a little work on the engine. Mainly just cleaning it up. Here are some pics before pics.
Before
My build thread:
350/TH350
Accuair e-level kit
Old 05-05-2014, 08:30 PM   #80
afmedic01
afmedic01's Avatar
More before pics:
My build thread:
350/TH350
Accuair e-level kit
Old 05-05-2014, 08:47 PM   #81
afmedic01
afmedic01's Avatar
Here are a few after I cleaned it up a little.
My build thread:
350/TH350
Accuair e-level kit
Old 05-05-2014, 08:53 PM   #82
afmedic01
afmedic01's Avatar
Threw a little paint on the block.
My build thread:
350/TH350
Accuair e-level kit
Old 05-05-2014, 09:11 PM   #83
afmedic01
afmedic01's Avatar
I picked up a couple of parts from Summit: Lunati Camshaft & Lifter Kit, Valve Train Components, Comp Timing set, crankshaft damper, & a melling oil pump.
(My three year old wanted his ride in the picture)
Not sure where to go from here. I originally wanted to keep the stock cylinder heads and intake manifold to save some $$$, but I am now thinking about purchasing a set of aluminum cylinder heads and a new intake manifold. Not sure which heads or manifold I'm going to go with yet. Any advice would be appreciated. Thanks.
My build thread:
350/TH350
Accuair e-level kit
Old 05-05-2014, 09:37 PM   #84
bcutt
bcutt's Avatar
Looking real good brother! Cant wait to see the body back on the frame.
Brandon
"Some of my finest hours have been spent on my back veranda, smoking hemp and observing as far as my eye can see."
- Thomas Jefferson
72 C10 SWB "Work in Progress"
bcutt is offline   Reply With Quote
Old 05-20-2014, 10:07 PM   #85
afmedic01
afmedic01's Avatar
Brandon
Thanks Brandon. I can't wait either, seems like its taking me forever though.
My build thread:
350/TH350
Accuair e-level kit
Old 05-20-2014, 10:54 PM   #86
mcbassin
Still Learning
mcbassin's Avatar
The motor looks great! Keep the pictures coming.
Old 05-21-2014, 01:03 PM   #87
afmedic01
afmedic01's Avatar
Thanks Mike. Wish is was as far along on my build as you are on yours. Your truck is looking awesome.
My build thread:
350/TH350
Accuair e-level kit
Old 05-21-2014, 01:26 PM   #88
Stickman
Stickman's Avatar
It's all looking good.
Stickman is offline   Reply With Quote
Old 05-21-2014, 03:04 PM   #89
afmedic01
afmedic01's Avatar
[QUOTE=Stickman;6687572]It's all looking good.[/QUO
Thanks.
My build thread:
350/TH350
Accuair e-level kit
Old 05-30-2014, 12:56 PM   #90
afmedic01
afmedic01's Avatar
Any one know the OD size for Porterbuilt lower control arms and trailing arms? I'm looking to purchase shaft collars to install my accuair sensors. Any help would be appreciated. This is what I had in mind.
http://images2.mcmaster.com/Contents...g?ver=20956529
I saw them on TXPinstriper "The Graduate" and JTP67-72 "Chained in Porterbuilt Prison" builds.
Thanks.
My build thread:
350/TH350
Accuair e-level kit
Old 05-30-2014, 02:37 PM   #91
JustCallMeDrew
JustCallMeDrew's Avatar
Hey bud sorry i cannot help you with that question but i have a question myself what did you use to clean the frame and what did you use to paint it?
1968 Chevorlet C10 work in progress no build thread yet!
JustCallMeDrew is offline   Reply With Quote
Old 05-30-2014, 03:09 PM   #92
afmedic01
afmedic01's Avatar
Drew,
I used oven cleaner on it first, then pressure washed it with hot water, put the grinder to it, and then used POR-15 Cleaner/degreaser and POR-15 Metal prep. I used urethane satin black paint. Hope this helps.
Sal
My build thread:
350/TH350
Accuair e-level kit
Old 05-30-2014, 03:14 PM   #93
JustCallMeDrew
Ok a few more questions how did you use hot water on a pressure washer i just hook mine to the water spicket and also what wheel did you use on the grinder?
Old 05-30-2014, 03:18 PM   #94
aggie91
I'm just glad to be here!
aggie91's Avatar
Thanks.
the rear trailing arms are 2" od and I think the front lowers are 1.25" od
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-30-2014, 03:23 PM   #95
afmedic01
afmedic01's Avatar
Thanks Karl. I'll be ordering the shaft collars today.
My build thread:
350/TH350
Accuair e-level kit
Old 05-30-2014, 03:25 PM   #96
lowlyfec10
dope!
lowlyfec10 is offline   Reply With Quote
Old 05-30-2014, 03:29 PM   #97
afmedic01
afmedic01's Avatar
Water spicket will work too. I hooked my water hose to the boiler (mine has a place to hook up a hose to it) only reason I used hot water. I do not recall which wheel size I used off the top of my head, but I did attach a wire wheel to grinder as well.
My build thread:
350/TH350
Accuair e-level kit
Old 05-30-2014, 03:33 PM   #98
afmedic01
afmedic01's Avatar
Originally Posted by lowlyfec10 View Post
dope!
My build thread:
350/TH350
Accuair e-level kit
Old 05-30-2014, 05:56 PM   #99
JustCallMeDrew
Ok thanks bud!
Old 06-02-2015, 03:55 PM   #100
Hart_Rod
Hart_Rod's Avatar
Updates?
Hart_Rod is offline   Reply With Quote
