Old 05-30-2014, 08:56 PM   #1
dman1982
dman1982's Avatar
a couple issues...
so on my swap, when its in 4 high its fine, but i got ballzy and tried 4 low, it wasn't working right, do i need to adjust my linkage on the transfer case? never messed with linkage, only reason i think its linkage is because it seems like its in-between gears...
rear end, i put a yukon posi unit in it, 4.56 gears, when i back up i hear a clicking noise like a u-joint, i changed the u-joints just incase and still making the noise, i heard that the posi diffs are loud and make noise, it backs up and goes forward good, just this weird noise at idle speeds
I'm using the stock linkage, I've seen other guys use it too, is there anyway to get passed just drive? can you adjust the linkage on these?
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 05-31-2014, 12:39 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: a couple issues...
as for the rear end, does it click around turns and such? The easy culprit is lack of Friction Modifier on the posi rear. I've also had a rear end click after it stripped splines off the axle (not trying to panic ya).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-31-2014, 12:09 PM   #3
dman1982
dman1982's Avatar
it clicks more around turns...but only does it a few feet then stops
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 05-31-2014, 06:03 PM   #4
dman1982
dman1982's Avatar
so.....
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-01-2014, 12:33 AM   #5
littlevictories
sounds like a posi. mine is stock from '66 and just ticked over 100k still makes a snappy poppy around corners.
you got the right juice in there?
littlevictories is offline   Reply With Quote
Old 06-01-2014, 08:38 AM   #6
dman1982
dman1982's Avatar
Ya, I put whatever the box the diff came in said to put in there, plus the additive
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
