Old 05-31-2014, 10:52 PM   #1
68wannabe
Disc brakes on factory c10 wheels?
Hey guys, I just had a question about converting disc brakes on my 1968 c10. If I do get disc brakes, will I have to get different wheels? They are factory 15" aluminum mag wheels. I have seen on some sites that sell disc brake conversions, saying the brakes will work on SOME 15" wheels. Anybody know which ones and if mine will work with them? Thanks! This is the truck. The wheels are like the front ones.
68wannabe is offline   Reply With Quote
Old 05-31-2014, 11:22 PM   #2
Lattimer
Lattimer's Avatar
Re: Disc brakes on factory c10 wheels?
Those are not original wheels to the truck, any aluminum wheel is either a much later model or aftermarket. Original wheels would be plain steel 6 lugs, with 3 nubs for the dog dish hubcaps.
Later 4x4 wheels with 4 nubs for the hubcaps will fit over later factory sized disk brakes. The conversion kits require the later (71 and up) steel wheels if you want the factory style 15's.
Aftermarket depends on what they are.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 05-31-2014, 11:28 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
Those wheels are aftermarket. Most disc brake conversions will be for a 5 lug wheel unless you are ordering a 6 lug conversion. So there is a good chance your wheels won't work.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 06-01-2014, 12:46 AM   #4
68wannabe
Yep, I just remembered that they aren't factory wheels. Don't know what I was thinking before lol There are 6 lug disc brake conversions, which I will most likely get. What about a wheel spacer? Has anybody tried this to see if it would work for a disc brake conversion?
Old 06-01-2014, 03:36 AM   #5
jocko
jocko's Avatar
68, Welcome to the site!
Which wheels do you want to have on your truck when you're done with the disk upgrade? The way you worded your first post, I'm thinking that you want to use the mags, yes? If so, I believe they should clear the brakes. If you can determine what year the mags were made (might be hard to do) then you could probably have a little more confidence in the guess. If they were made 71 or later, they will probably clear them just fine - I agree with Lattimer that they probably were later than 71. Same-same for stock steelies, if you'd like them at some point - 71 or later will clear the calipers. But, don't forget that for stock steelies post-1970, 6 luggers only came on K5/K10. C10s went to 5 lug at that point (also as Lattimer and toomuchstuff pointed out). The reason the sites say the kits work on "some" 15" wheels is because they don't work on some also. Pre-factory disk brakes, the inner side of the wheel had a taper between the rim and the wheel center that will rub on the caliper in some conversions. Looking forward to seeing a build thread on your disk brake conversion!
Old 06-01-2014, 07:42 AM   #6
cdowns
cdowns's Avatar
those mags are late 70's early 80's and should b no problem clearing dics brakes
Old 06-01-2014, 10:24 AM   #7
leddzepp
Moderator
leddzepp's Avatar
x2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-01-2014, 10:35 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
X3
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-01-2014, 10:42 AM   #9
70blackfish
x4
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 06-01-2014, 11:44 AM   #10
68wannabe
Thanks guys! That is some great news. I really want to keep these wheels for it, mainly because I don't want to buy new ones and actually just really like the looks of them. Again, thanks for the help!
Old 06-01-2014, 12:04 PM   #11
Tx Firefighter
If you want to stay married to those wheels and you think its time to spice up your relationship, here's what you need. Eagle 1 etching mag cleaner. It's meant for cast wheels like that and will make them look like they did 20 years ago.
Old 06-01-2014, 08:52 PM   #12
profe56
Thanks Tx for the mag cleaner info. Is it available at auto parts store?
profe56 is offline   Reply With Quote
Old 06-01-2014, 10:22 PM   #13
Tx Firefighter
Yes, it's a parts store item. There are two different Eagle 1 wheel cleaners (at least). Be sure and get the etching one. Its aggressive and not fit for polished wheels but it's the bees knees for cast aluminum rough finish wheels like you have. Truly amazing results.
Old 06-06-2014, 02:42 PM   #14
profe56
Thank you TX Eagle 1 etching is gerat for cleaning mag wheels.
I'm having problems for posting pictures to show before and after. I tried others but this one is great. thank you again.
Old 06-06-2014, 03:02 PM   #15
leddzepp
Moderator
leddzepp's Avatar
It works wonders on slotted mags too.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-06-2014, 04:13 PM   #16
Tx Firefighter
I'm glad you're pleased with the outcome. You spent some money on my recommendation so its nice to hear you feel it delivered up to expectations.
