Old 10-01-2013, 05:11 PM   #76
RoadRat
RoadRat's Avatar
Re: HOW TO: Crossmember sectioning ...
Chief, Thanks for the write up! Here is a nudge on finishing the steering!
RoadRat is offline   Reply With Quote
Old 10-01-2013, 06:16 PM   #77
63suburban
63suburban's Avatar
Excellent write -up! Thanks for taking the time.
1963 Chevrolet Suburban
63suburban is offline   Reply With Quote
Old 10-02-2013, 07:08 AM   #78
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thanks for the much needed nudge ....
Super busy at the shop, gotta make time !
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 10-02-2013, 11:55 PM   #79
pimpston65
pimpston65's Avatar
life does "get in the way" of our projects, been working on mine since 98' and just now bout to finish my complete frameoff resto. man that frame work is Bad Ass.
pimpston65 is offline   Reply With Quote
Old 10-03-2013, 01:17 AM   #80
jayman68
Fun Stuff
jayman68's Avatar
Originally Posted by jessfloho View Post
yeah thank you very much for passing this on. I just finished putting my front suspen together using this method, turned out great. I also found some bag cups that I welded in to give me more travel. Now I'm having to deal with the steering, because of the added travel my steering shaft is hitting my control arm, anyone have any ideas?
I would suggest rack and pinion steering,
http://67-72chevytrucks.com/vboard/s...d.php?t=465423
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 10-04-2013, 10:15 AM   #81
BRASSHEAD
BRASSHEAD's Avatar
How are you going to brace the upper a-arm bracket? The holes are now above the frame.
BRASSHEAD is offline   Reply With Quote
Old 10-04-2013, 10:27 AM   #82
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Definitely a way to it.
Modifying the stock steering is my intention here.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-04-2013, 10:30 AM   #83
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
This can be accomplished a couple ways.
Angle, tubing ....
I was planning on molding the reinforcement into the frame.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-04-2013, 06:06 PM   #84
mr andrerson
thanks for all the great pics and write-up chief! ill be watching for sure!!
mr andrerson is offline   Reply With Quote
Old 02-06-2014, 11:50 PM   #85
Kyle@FTP
Awesome thread and great write up. Curious as to why you go to the newer style crossmember?
Kyle@FTP is offline   Reply With Quote
Old 02-07-2014, 08:03 AM   #86
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Hey Kyle ....
A '63 and UP crossmember does not need to be changed.
I only changed it because I wanted to get rid of the Torsion Bars (60-62), and upgrade to a coil suspension.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 02-07-2014, 10:10 AM   #87
Kyle@FTP
Thanks makes sense now that I think about it. I have a 67 GMC that I will be doing the same thing to. So this was a great thread to run across.
Old 06-01-2014, 12:44 AM   #88
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I've been reading lots of threads on Sectioning, Z-Frame, and Notching the Crossmember.
It took me awhile to visualize what is happening with each option, and I really like the Sectioning method the best for one major reason. The Crossmember Notch, and Z'-Frame both raise the motor. Or I should say; lower the body and frame down without lowering the motor in relation to the drop.
But with the Sectioning of the Crossmember, the motor drops along with the frame and body.
For many of us 60-66 guys, this works out better. Because a lot of us running an HEI are already right up against the firewall with the cap. Lowering the body and frame without lowering the motor could cause us some issues with our distributor caps hitting the firewall.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-04-2014, 09:57 PM   #89
Lowl!f3
Lowl!f3's Avatar
If you move the engine forward. You can solve that issue and create newer ones with possible recessing radiator or going with electric fans. Everything causes some type of issue. Sectioning will cause steering issues. Either way you choose it can be worked out. I'm going to section my xmember without Z.
1965 C10 Project
Lowl!f3 is offline   Reply With Quote
Old 06-06-2014, 08:04 AM   #90
jjzepplin
jjzepplin's Avatar
You are right sir. We all become GM engineers at some point in our builds. This site brings all of us together. Not sure I would tackle this. But I'm thinkin about it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-25-2014, 12:16 AM   #91
rico12410
thank you very much for the write up chief!
rico12410 is offline   Reply With Quote
Old 01-24-2015, 01:50 AM   #92
PowerdbyChevy79
PowerdbyChevy79's Avatar
trying to give this thread some life!!! ..hey chief...did you ever finish the burban..
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 01-24-2015, 03:31 AM   #93
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thanks man ....
Not yet, but it's going pretty good.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-24-2015, 07:55 AM   #94
PowerdbyChevy79
Cool cant wait to see some pics...
Ok question...is putting a crossmember from a 71 a bolt in and then just transfer all the steering over (a-arms,draglink,pitman,idler arm) and what about the back..i have no experience with torsion bar set up.im buying a 60 panel and i want to drop it...
1966 C10 "Mary"
Old 01-24-2015, 09:20 AM   #95
WEBBY1
WEBBY1's Avatar
This thread helped me quite a bit
WEBBY1 is offline   Reply With Quote
Old 01-24-2015, 12:16 PM   #96
Chevy Fleetside
Chevy Fleetside's Avatar
Need to take a cruize down to your neck of the woods with Luca some weekend.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 01-24-2015, 02:29 PM   #97
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
More pics are in the actual build thread ....
The crossmember will swap into a 62 and earlier chassis, but you need to redrill some holes.
This is beneficial in centering the wheel in well in dropped applications
Im glad !!
Anytime .... im headed to Turlock in a few
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-25-2015, 09:37 PM   #98
doublebeetx
How does it help in centering the front wheels ?
doublebeetx is offline   Reply With Quote
Old 01-25-2015, 10:42 PM   #99
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
By relocating the crossmember about an 1" forward, it centers the wheels in the fender opening.
This would be in dropped, bagged situations
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-25-2015, 11:10 PM   #100
doublebeetx
I thought about that, but what do you do about the taper of the frame ? My 64 begins to taper in just ahead of where the crossmember originally bolts in. Sorry to ask too many questions
