a couple issues...
so on my swap, when its in 4 high its fine, but i got ballzy and tried 4 low, it wasn't working right, do i need to adjust my linkage on the transfer case? never messed with linkage, only reason i think its linkage is because it seems like its in-between gears...
rear end, i put a yukon posi unit in it, 4.56 gears, when i back up i hear a clicking noise like a u-joint, i changed the u-joints just incase and still making the noise, i heard that the posi diffs are loud and make noise, it backs up and goes forward good, just this weird noise at idle speeds I'm using the stock linkage, I've seen other guys use it too, is there anyway to get passed just drive? can you adjust the linkage on these?
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
#2 | |
meowMEOWmeowMEOW
Re: a couple issues...
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
it clicks more around turns...but only does it a few feet then stops
so.....
sounds like a posi. mine is stock from '66 and just ticked over 100k still makes a snappy poppy around corners.
you got the right juice in there? |
Ya, I put whatever the box the diff came in said to put in there, plus the additive
