06-02-2014, 11:33 AM | #1 |
No idea what this button does
Hello all. I'm restoring a 1967 Chevy C10. I'm a novice and learning through youtube videos, forums and manuals. I installed new carpet and have come across this button pictured. What is this button's function. Any info is appreciated.
06-02-2014, 11:42 AM | #2 |
Re: No idea what this button does
It looks like the high-beam headlight switch. Either that or ejection seat - try it out to see what happens.
Hook'em |
06-02-2014, 11:49 AM | #3 |
Junior Member
switch for hi and low beam on headlights
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
06-02-2014, 11:51 AM | #4 |
Thanks. Definitely not an ejections seat! LOL.
My headlights aren't working now (the brake lights do though) and they did last week. Same for my cabin light. Do you this this switch is the culprit? Should I check the connection? Thanks! Also attached a pic of my fuse box. |
06-02-2014, 11:55 AM | #5 |
Personally, I would check your headlight switch first, mine is on the fritz and I have to play with it sometimes to get interior/dash/or headlamps to come on.
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
06-02-2014, 11:55 AM | #6 |
There may be a link between the switch and the headlights not working. Back in the day, I was driving my Pontiac LeMans back to school and hit the headlight dimmer switch which made the headlights go out. I had to drive a few more miles up the road with parking lights only. I can't remember the fix, only that there was a connection between the switch and the loss of headlights.
Hook'em |
06-02-2014, 12:02 PM | #7 |
Check to see if your hi beams work or if just low beams are not working, I think the 3 wires at the bottom of your pic blue,green,tan are the ones that go to the hi/low beam switch. but if your dome light is not working then you might have a bad or dirty headlight switch, I have gad to pull my headlight switch and clean it up to get the dash lights and the dome to work good. the dome light should be a white and orange wires coming from fuse panel.
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
06-02-2014, 12:02 PM | #8 |
Project Junkie! Fishing Poor!!
It could be either. Check them both. Lift the carpet and see if the connector is melted on the high beam switch or if moisture hasn't corroded the switch itself. It also could be your wiring. Looking at the fuse panel, it looks to have lots of corrosion. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
06-02-2014, 12:03 PM | #9 |
this might help as well.
06-02-2014, 12:38 PM | #10 |
Lmao....ya spit out my coke on that one.....
1966 C10 Mary 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
06-02-2014, 02:02 PM | #11 |
Location: Formerly MD and San Diego, now loving life in Arizona
I had a problem with that dimmer switch on my '69 GMC. Whenever my headlights decided to flicker or stop working, I pumped that floor switch a half dozens times and everything would work normal again. My switch had corroded contacts in it and caused all the problems. Replaced the switch - problem never came back.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
06-02-2014, 02:17 PM | #12 |
Thanks everybody. I'll take a look at it all tonight and let you know. Appreciate your help!
06-02-2014, 02:45 PM | #13 |
Like said before me, the headlight switch may be bad. I had issues with my interior lights and headlights, replaced the little box behind the switch and voila.
06-02-2014, 03:45 PM | #14 |
The Older Generation
I think I would agree with Wes. The fuse holders look pretty rusty and crusty.... I would clean those first.... LockDoc
06-02-2014, 05:45 PM | #15 | |
Let us know what you find.
06-02-2014, 05:53 PM | #16 |
Any suggestion on what I should clean the switch and fuse holders with? Do I need to remove the fuse box?
06-02-2014, 05:54 PM | #17 | |
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
06-02-2014, 06:12 PM | #18 |
CRC makes a spray on electronics cleaner. You can get it at most any auto parts store. I'd spray it on then blow it dry with compressed air.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
06-02-2014, 07:32 PM | #19 |
Once you get used to the floor-mounted dimmer switch, you will rail against the steering column-mounted ones.
06-02-2014, 11:59 PM | #20 |
Ya get some electronics cleaner...if you cant find any ata auto parts...air conditioning supply houses sell it..
06-03-2014, 10:03 AM | #21 |
Cleaned off the dimmer switch and reconnected. And the headlights came on. Thanks for your help everyone.
06-03-2014, 02:18 PM | #22 | |
My son had the same question when I brought my truck home. He also quickly found out that you do not need to press the brake for the shifter to move out of park.
Only Two...... Only two have laid down their lives for you, Jesus Christ and the American GI. 2007 Chevy 2500HD 4x4 Duramax 1970 Chevy K20 (SOLD) 1972 Chevy C15 (1/2 C10, 1/2 c20) 1970 Chevy C10 (parting out) |
