Old 06-02-2014, 12:23 PM   #1
aotte1
What Year is This 5 Blade Fan?
Trying to ID what year(s) this 5 blade fan is correct for, tried to match it to search pictures with no luck. Thank for the help.
Les
aotte1 is offline   Reply With Quote
Old 06-02-2014, 02:09 PM   #2
aotte1
Re: What Year is This 5 Blade Fan?
Just FYI, to add a little to maybe help others, the following is a four blade fan found on both 1965 and 1966 "292" 6 cylinder engines. The 1965 was on a low mileage one ton military ambulance, the 1966 is from a C10 pickup, both appeared to very original.
Les
Old 06-02-2014, 02:11 PM   #3
aotte1
Other side of 65, 66 fan. Still need info on first fan picture year/ engine if applicable.
Old 06-02-2014, 02:13 PM   #4
aotte1
Close up of fan spacer.
Old 06-02-2014, 02:17 PM   #5
aotte1
Picture of both spacer and shim?
Old 06-02-2014, 02:20 PM   #6
aotte1
Yes, I sometimes use the ceiling for extra space in garage
Les
Old 06-02-2014, 03:31 PM   #7
chevyrestoguy
chevyrestoguy's Avatar
Most all GM fans will have a part number stamped into it somewhere on the part, and it'll almost always start with the number "3". Find the part number and type it into Google and see what comes back. You may get lucky and it'll pinpoint the year and application.
What part of Louisville are you from? I was born and raised in the South End, around Iroquois Park. My brothers are still there, and they live in Okolona, near Moore High School.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 06-02-2014, 03:47 PM   #8
LT1 Burb
LT1 Burb's Avatar
That is the same fan that is on on my 65 283 with the fan shroud and air.
LT1 Burb is offline   Reply With Quote
Old 06-02-2014, 05:27 PM   #9
63burban
Chevy addict
Earlier Chevrolets use a smaller bolt pattern on the blade mount, not sure what year they changed but I know in the early 70s they used the blade you have pictured.
63burban is offline   Reply With Quote
Old 06-02-2014, 06:11 PM   #10
60-66
60-66's Avatar
Is there a big "U" shape stamped in each blade around the outside of the rivets ? I don't recognize that blade at all. 292s with heavy duty cooling or V8s with AIR have a 5 blade fan similar to yours but are all 5 rivet per blade fans. The only marking on the fan is a "W" . No part number. The GM Part numbers for these blades are 3770262 or 3789562. Below is a flat rivet style and an earlier round rivet style.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 06-02-2014, 08:39 PM   #11
LT1 Burb
LT1 Burb's Avatar
Ok, I just looked and mine has 5 rivets also.
Old 06-02-2014, 09:12 PM   #12
RANDY COX
RANDY COX's Avatar
Mine has the round rivet style..
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 06-02-2014, 10:50 PM   #13
aotte1
60 - 66,
Yes, there is a u in the blade, will look for the "W" stamp.
Thanks for the help,
Les
Old 06-02-2014, 11:01 PM   #14
aotte1
63 Burban,
In My search of pictures, did find 70-72 image of fan with similar rivet pattern, not sure if original to that truck, could not see blades in that picture.
Thanks,
Les
Old 06-02-2014, 11:07 PM   #15
aotte1
Chevyrestoguy,
We live south of Louisville toward Fort Knox , a little bit off of I 65.
Will examine fan to look for any markings.
Thanks,
Les
Old 06-03-2014, 09:51 AM   #16
jchav62
1962 C-10
jchav62's Avatar
I think some of the trucks built for northern climates had 3-blade fans too.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
