Old 06-02-2014, 09:42 PM   #1
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Blazer tank in SWB
I know that this is an old school tank relocation thing, but I wonder if it is still the best tank to use on a 4-inch lowered SWB truck. '69 Camaro tanks also work and there are aftermarket tanks, in plastic or metal. My budget won't allow for the full-on custom route. So, I'm thinking that a metal Blazer tank kit is a good fit.
Anyone got any comments or thoughts? Thanks.
Member Nr. 2770
Old 06-02-2014, 10:22 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Blazer tank in SWB
I put a blazer tank under my blue 72. I won't ever do it again. Trying to make a filler work out was a real pain. I'm leaving all my tanks in the cab from now on. Just my opinion.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-03-2014, 09:50 AM   #3
67c10rustbuket
67c10rustbuket's Avatar
Blazer tank "kit" from LMC, $200 and you get to cut you about 2" out of your bed cross sill for the width of the frame to get it flush against the frame. Not to mention all the other complaints I have read about them.
Boyd welding tank, Standard NON-EFI, bed fill. $349. Drill 4- .5" holes in the aluminum tank mounting flange and install 4 bolts ( in existing holes in the frame).http://www.fueltankparts.com/67-72-s...-bed-fill.html
Personally I would spend the extra for the Boyd tank. I see lots of people buy a blazer or other kit and have to mod all kinds of parts and the frame to make it work.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 06-03-2014, 09:59 AM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'd leave the in-cab tank in place and use the $$ elsewhere on the build. If you do the swap, adding the fuel filler neck in a position similar to what GM did for the 1970 aux tank option may be the path of least resistance but upper trim could interfere with the bedside outer hole location.
Old 06-03-2014, 11:06 AM   #5
RRR18
RRR18's Avatar
I have "Blazer" tank in rear of my '67. Kit came from Brothers. My rear is 7" down. Ya, as others have said there needs to be some mods made to make it work and fit correctly. Seems like I gotta mod a lot of stuff anyways so didn't seem like big deal to me.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 06-03-2014, 01:10 PM   #6
oldschool18
oldschool18's Avatar
I got a blazer tank....... didn't have to cut the frame but did have to cut a hunk out of one of the rear bed supports. But I'm running my filler hose up into bed, the tank lmc makes I don't think you have to cut anything just a hole in the bed floor cause the tank is a few gallons less then the blazer tank and the filler sticks straight up in the middle of the tank.
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 06-03-2014, 01:24 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Okay, I hear you all loud and clear. So, it seems I'd be better off keeping my OEM tank (which is in good shape). I would like to do away with the odor of gasoline, tho.
As I recall removing the OEM tank, I can't think of anything except the sending unit gasket that would be a source of an odor. So, I'll check it out some more.
Thanks for the feedback.
Member Nr. 2770
Old 06-03-2014, 01:55 PM   #8
Lee H
Lee H's Avatar
If the tank is not leaking the odor is coming from the rubber hoses connecting the hard lines or sending unit o-ring. Replace those and you will not have any odor. There are a few hoses that connect the hard lines to the sender, at least on mine a rubber hose from the neck to the tank (maybe part of the venting?). Also check the condition of the rubber connecting the hard lines under the cab and the tank neck to cab grommet. I see no logical reason to move the tank from the cab unless maybe your doing an LS swap. IMHO, there are a lot better mods to use that cash on.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-03-2014, 06:35 PM   #9
68Gold/white
The blazer tank can be adapted w/ blazer straps, the biggest pain is the filler neck. Neither my 67 or 68 will drive down the road again w/ a gas bomb in the cab!!!
There's a thread here about someone making a nifty filler neck that hides behind one of the tail lights. He's had other things going on, I need to check on that again...
68Gold/white is offline   Reply With Quote
Old 06-03-2014, 06:48 PM   #10
leftybass209
leftybass209's Avatar
I Don't know if you have ever seen a gas tank explode but you're no less or more safe in the cab with the tank than you are with it 6 feet away ready to flip the truck upside down in an explosion. You're much more likely to die from any vehicle impact than by a fuel tank exploding. I know, Humvees get blown up in Iraq and Afghanistan daily during peak War times.
leftybass209 is offline   Reply With Quote
Old 06-03-2014, 07:13 PM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I looked at a locally advertised LWB Cheyenne Super 72 K10 last night. The guy told me of a head on collision he had in a 70 LWB 4wd truck that sent his truck over the top of the other car and onto its side in a ditch. I asked him if the tank leaked - he looked at me a little puzzled and said "No" - it was driver side down.
Old 06-03-2014, 07:31 PM   #12
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
I vote for the Blazer tank, however it is not for safety concerns. You will hear all kinds of people report problems like filling the tank, fitting a gas filler door etc. It is a customization on your truck, and customizing isn't always easy, but this conversion is. You can go to my website and there is a big write up about how to do it in my how to section. I have done it, and as long as your filler hose heads down hill the whole way from the filler to the tank it will fill up just fine. Also don't forget to use all of the vents in the tank, do not plug any. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
