Old 06-03-2014, 07:36 PM   #1
donthekawguy
donthekawguy's Avatar
Anotherr upper control arm ?
Searcged couldn't find it. Are the shafts and ucl's threaded? They look like they have threads on them and I can only get the shaft ends on about half way with a breaker bar. I had the arms powder coated and they didn't tape off the inside of the holes so I think that is the problem. I might have to wire wheel the opening that the ends go into.
66 shorty
donthekawguy is offline   Reply With Quote
Old 06-03-2014, 11:54 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Anotherr upper control arm ?
If you are using stock '63-'72 arm, then yes they are threaded both internal and external. If you have powder coating in the threaded part of the arm, you'll need to clean that out or you might have some problems getting it to thread on. Make sure your shafts are centered on the arms.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-04-2014, 12:38 AM   #3
donthekawguy
Yeah they are stock. I wish I would have told them to tape off the hole. Oh well live and learn. Good thing I have a bunch of dremel wire wheels and time.
66 shorty
