another engine swap question
i have a 64' chevy c20, I6 230, my buddye has a 350 out of a 77 c10, would his motor bolt right up to my mounts?
also my trucks is sitting on coil overs, already have trailing arms and the works galore. can someone tell me where to buy fender flares? I've changed my mind from restoring it to making it a race truck ( i know it sounds bad ) |
Re: another engine swap question
A 350 is an SBC and will bolt in just like any other.
Are you sure you actually have coil overs? Stock C10-20's had coil springs and trailing arms in this era, and I'd bet money that's what you have, not coil overs. |
im glad you caught that, yes i have coil springs in the back, the front is currently under-going a coil over conversion fabrication what ever you want to call it. i won't have to move any engine mounts or get brackets?
No, its a direct bolt-in. You'll still need to come up with a radiator/fan shroud setup that works, but it's a direct no-mod swap.
