8 lug to 5 lug conversion - what do do with the rear end
I'm considering changing from a 8-lug wheel pattern to a 5-lug wheel pattern. With the front I am thinking about going with EarlyClassic.com's C20 3/4 ton to 1/2 ton spindles and getting the 5-lug rotors.
My question is what do I do with the rear end. It is an 8-lug 14 bolt rear. The truck is a 1985 GMC Sierra Classic 2500 3/4 ton crew cab LWB. The ultimate goal is to install a PorterBuilt DropMember front and rear. ![]()
![]() /Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat / SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed |
Never Ending Projects
Re: 8 lug to 5 lug conversion - what do do with the rear end
You will likely need to swap out the rear end for a 5 lug 1/2 ton version. Should be tons of them available in any junk yard. Find one with the right rear end ratio that you want. Should bolt right. You might need the 1/2 ton driveshaft as well, as I think the u-joints are different then 3/4 ton.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
They make conversion hubs but they are expensive. It would be cheaper to find a used 5 lug.
You can get conversion spacers (though there is a safety concern with that for some).
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Biggest issue is likely going to be the center hub size. 8 lug hub bore is huge compared to a 5 lug setup. I don't think you would find 5 lug wheels that would fit over the hub, unless you used an adapter that made it flush with the end of the hub.
The real question is why?
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
#7 | |
I am going to install a full Porterbuilt air ride suspension on it; bought it with this sole intent. I thought keeping with the 8-lug setup would help make is standout a little from other dropped C10's but the wheel selection is severely limited with the 8-lug for the sizing and fitment I'm looking for versus the 5 lug patter.
Answers my question.
#10 | |
Check out these (you have to scroll down a bit to get past all the dually rims): http://4wheelonline.com/American_Force_Wheels.29008
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy Last edited by tinydb84; 06-04-2014 at 01:15 PM. |
