Old 06-06-2014, 04:38 PM   #1
ACII
Door alignment ..need help ?????
Hy all
So far the vertical and horizontal position is ok, but the door is not even with the cab...that means on the height of the door handle it is overlapping and on the lower part it is dipping to deep..
Tomorrow i will upload some pics, maybe it is a bit easier for u to understand my problem....sorry for my poor english.
I hope you have some advices for me
Thanks a lot
Regards
Achim
ACII is offline   Reply With Quote
Old 06-06-2014, 05:13 PM   #2
Rc4mike
Re: Door alignment ..need help ?????
My cab spread slightly making door alignment real tough.
Rc4mike is offline   Reply With Quote
Old 06-06-2014, 05:17 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
The easiest way to adjust doors is to loosen the bolts with someone inside to tighten them. With the bolts loose, close the door, adjust the door to where the gaps look good and the lines are correct, while you hold it in place have the person inside tighten every thing. This will get you very close to where it needs to be.
Old 06-06-2014, 05:20 PM   #4
ACII
thanks for quick response...gonna try this tomorrow. :-)
I will give feedback
Cu
Achim
Old 06-06-2014, 05:22 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
They do seem to spread as your doing gaps, if it truly has then get a strip of 18 or 16 ga. metal and weld it to the cowl door sill or rear door sill of cab it will take up the gap width nicely.
Old 06-06-2014, 07:51 PM   #6
OrrieG
OrrieG's Avatar
My experience has been they were not perfect from the factory, usually you can pick two line the front and top to get perfect and live with the other two, or resolve yourself to adding of deleting material. If its an AD stovebolt.com has a lot of tech articles on alignment. MartinSR usually chimes in with his info too, if you search it should show up.
Old 06-07-2014, 11:56 PM   #7
Iceburgh
Iceburgh's Avatar
They are tough to get. If you have not done the body work yet I would suggest get it close, cut the cab in a pie shape and move in and out as needed. Tack,weld grind and fill
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
