74 K5 Low Bucket driver seat ( need Help )
Driver seat has 4 bolts on front of seat where seat bolts to floor , 2 bolts closest to center console ( on rear of seat ) , can anyone tell me what 2 are closest to door ( rear seat bracket on front driver seat ) . Mine has 2 studs sticking up from the floor , but they are not tall enough to go though the seat bracket where it bolts to floor . How do I get threaded studs out ? when I bought it , the seat was not bolted down ? How does a 74 front bucket seat bolt down ?
Re: 74 K5 Low Bucket driver seat ( need Help )
Can u remove the studs? My just has bolts that go through the floor board (floor board is threaded)
I am going to try heat and vice grips
Pb blast better than wd 40 spray it leave it I've used it on bolts rusted in exhaust manifolds
All the seats should be bolted in from the top.
Having "studs" sticking up only makes sense if the bolt broke, or someone "customized it". Should be 1/2" Coarse thread If I remember. Remove the seat and put two nuts on the stud to help remove it. +1 On PB-Blaster. Spray, soak wait, spray, soak, wait over a couple of days. (use a breaker bar) If that does not work (and it should) then apply heat. |
Thanks !! I have not had time to mess with it yet . LONG list of things to fix .
