Old 06-10-2014, 09:04 PM   #1
westpoint
what kind of gears in my housing?
I have a 82 Silverado. When the rear is off the ground and I spin one tire the other tire travels opposite. I would like to get posi but I need the truck for the street. What do I have now? Also what do I need for the street but no one wheel wonder? Thanks.:metal
westpoint is offline   Reply With Quote
Old 06-10-2014, 10:25 PM   #2
J Knight
J Knight's Avatar
Re: what kind of gears in my housing?
"Most likely" in an 82 you have a 10 bolt with 2.75 or 3.08 open diff.
You can remove the rear cover and count the teeth on the ring and pinion then divide one into the other to get your gear ratio. You might find the tooth count stamped on the ring gear.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 06-11-2014, 07:17 AM   #3
riz
You can also count how many revolutions your driveshaft turns for one rotation of your tire. Simple math.
RIZ
riz is offline   Reply With Quote
Old 06-11-2014, 07:25 AM   #4
xrcr
You can go to gm heritage.com and see what that truck came with and then do the spin deal
xrcr is offline   Reply With Quote
Old 06-11-2014, 09:51 AM   #5
westpoint
i count 12 bolts on the housing cover. whats that tell me?
Old 06-11-2014, 09:58 AM   #6
J Knight
J Knight's Avatar
From what I have read, they stopped putting 12 bolt rear ends in trucks in '81 so it might have been swapped from a 10 to a 12 at some point. You need to count the teeth or spin the wheels and count the revolutions of the yoke to find out what ratio you have.
John
Old 06-11-2014, 02:09 PM   #7
westpoint
How do you count the revolutions of the yoke?
Old 06-11-2014, 02:45 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Jack one rear wheel off the ground. Put transmission in neutral. Turn the wheel two turns exactly. Count how many times the yoke turns as you turn the wheel twice.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-14-2014, 04:48 PM   #9
westpoint
Looks like I have a 2.63 gear ratio. 43 and 16. What does that tell me? Im not sure how gears work. Confusion to me. If I upgrade to a Eaton posi unit which one do I buy?
my dad recommends a 4.11. What do you think and when can I get one decent price? Thanks.
Old 06-14-2014, 05:17 PM   #10
Keith Seymore
Keith Seymore's Avatar
4.11 is pretty steep. It will deliver a big jump off the line but not very good fuel economy. 2.63 (43/16=2.68) will deliver better fuel economy (assuming it is not bogging/lugging the engine) but will be a dog off the line.
For all around street use I like a 3.73-ish when I have an overdrive trans, or a 3.42-ish when the highest gear in the trans is a straight 1:1.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 06-14-2014, 06:25 PM   #11
J Knight
J Knight's Avatar
What do you plan on using the truck for? What motor, tranny, and tire diameter do you have or plan on having? All these things and more play into picking the right gear ratio.
John
Old 06-14-2014, 07:36 PM   #12
westpoint
Im looking to keep the truck tire size and stance close to stock. Right now it has a 305 in it. I would like to put a bigger motor in it eventually or just increase the horse power in the 305. I will be using this truck to drive everyday. 10 miles one way to work plus errands. Hope that helps.
I have another dilemma.... I removed the drive shaft. I also remove the front of the differential where the seal cap, bearing and race are. How do I remove the race? Do I need to remove all the gears in the housing to replace the race for the new bearing? Thanks for all the help.
Old 06-15-2014, 12:11 AM   #13
J Knight
J Knight's Avatar
K
I would go with Keith's recommendation.^^^
John
