Old 06-11-2014, 01:43 PM   #1
PowerdbyChevy79
PowerdbyChevy79's Avatar
rear sway bar
Whats up c10 family... i wanted to see if y'all could help me..where can i get a rear sway bar for my 68..did they make these trucks with rear sway bars from the factory....or is this strictly an aftermarket product..your info would be much appreciated...
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 06-11-2014, 01:48 PM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: rear sway bar
Thay never came on a C10 from the factory and I'm pretty sure not on the
C20's and C30's as well but can't be 100% sure on that one. I know Addco and Hellwig make rear sway bars for our trucks.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-11-2014, 02:20 PM   #3
hugger6933
Re: rear sway bar
Camaro rear sway bars will work and work real well if you have coil springs instead of leaf springs. Do a search here and find the post I don't have it saved and aren't computer savvy enough to tie links together. I think it may be in the truck tech or the FAQ's on the top of the page in the upper left hand corner. Look there first, you should spend some time in there any way. Jim
hugger6933 is offline   Reply With Quote
Old 06-11-2014, 05:18 PM   #4
cdowns
cdowns's Avatar
Re: rear sway bar
rear sway bars not a factory option at anytime
they are readily available from jcwhitney lmc broters and all the local vendors can get them for you
Old 06-11-2014, 05:58 PM   #5
PowerdbyChevy79
Re: rear sway bar
do you know what year camaro's will fit?
1966 C10 "Mary"
Old 06-11-2014, 06:58 PM   #6
SS Tim
SS Tim's Avatar
Re: rear sway bar
67-72 conventionals "C" or "K" trucks were not offered with rear stabilized bars. However from 68-72 the P30 SRW step vans did, something to to look into if you see one at a yard. Of course the later 73 up pickup trucks C20-30 offered rear stabilizer bars as part of the Z81 Camper Special equipment packages.
SS Tim is offline   Reply With Quote
Old 06-12-2014, 12:48 AM   #7
UP GRADE
one set closer
UP GRADE's Avatar
Re: rear sway bar
Here's a couple
http://67-72chevytrucks.com/vboard/s...d.php?t=334003
http://67-72chevytrucks.com/vboard/s...ad.php?t=47603
UP GRADE is offline   Reply With Quote
Old 06-12-2014, 10:35 AM   #8
bonnieclyde100
Re: rear sway bar
late eighties camaro and firebird cars work good .i have the firebird ones on mine i will post some pics tonight when i get home. easy install just drill a few hole and bolt up
bonnieclyde100 is offline   Reply With Quote
Old 06-12-2014, 01:06 PM   #9
J kippin
J kippin's Avatar
Re: rear sway bar
I have an IROC Z bar in mine. It was the biggest that the General used for these cars. I have dropped the rear 4.0 and the front 3.0 and also run a 1.25 bar up front.
Using KYB shocks this truck is more fun to drive than my Vette
J kippin is offline   Reply With Quote
Old 06-12-2014, 01:56 PM   #10
Bigdav160
Bigdav160's Avatar
Re: rear sway bar
More fun than two Vettes?
I have an Addco front and rear on my Suburban. Since my exhaust runs where the rear should have been mounted, I modified the mounting. No pics, the Burb is at the shop.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-12-2014, 03:17 PM   #11
J kippin
J kippin's Avatar
Re: rear sway bar
Nice looking Vettes.
I believe the Iroc Z bar is 25mm., use along with a 1.25 bar used on c20/30 trucks up to 87.Poly mounts and new poly cab bushings will make it handle decent. Rob from No Limit makes a great kit and has some great advice on how to set up these old trucks.
Mine is set up as a cruiser but handles decent for what it is.... A long bed POS with a 496.
Name:  71 c10 004.jpg
Old 06-12-2014, 06:45 PM   #12
Lattimer
Lattimer's Avatar
Re: rear sway bar
Mine is a Hotchkis bar for a 1980's Camaro. Found it on the parts board for cheap. Pics are in this post: http://67-72chevytrucks.com/vboard/s...&postcount=121
I had to modify a bit to make it mount up nice. Its not perfect, the links should be vertical, but to fit and miss everything I had to angle them. It does stabilize the truck a lot, especially on highway on ramps. It has a weird feel to it, when you corner hard you can feel the rear of truck sort of lift up. Feels like its going to skid until you get used to it.
The bar does limit the amount of power you can apply in a corner without losing traction.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 06-12-2014, 06:52 PM   #13
slowcpe
slowcpe's Avatar
Re: rear sway bar
I thought I read on the "make it handle" thread that No Limit had a rear sway bar but I can't find it on their website. I'm interested in running one too.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 06-12-2014, 08:00 PM   #14
seafoam68
seafoam68's Avatar
Re: rear sway bar
I have front and rear from CPP. I have heard that one should not use a rear one if truck is lowered. Anyone know if this is true and why? Mine is not on road yet so I don't know. Good luck.
seafoam68 is offline   Reply With Quote
Old 06-12-2014, 08:27 PM   #15
J kippin
J kippin's Avatar
Re: rear sway bar
don't know what you are referring to about lowered trucks and no sway bars.
Like stated mine is lowered and I have no issues. Run a bigger bar in the front to help balance out the truck.
The Iroc bars mount to the rear axle and have end links that mount to the frame. Keeps everything nice and tight out of the way.
When you do lower make sure you change the track arm or sometimes called a panhard bar I use an adjustable one.
Name:  71 c10 001.jpg
Old 06-12-2014, 10:03 PM   #16
bonnieclyde100
Re: rear sway bar
here is a pic of my swaybar
Old 06-12-2014, 11:48 PM   #17
Lattimer
Lattimer's Avatar
Re: rear sway bar
If you are too low I could see having issues making one fit. Mine is only lowered 2", so I didn't have any issues.
I still want to get a fatter bar for the front.
Shawn
Old 06-13-2014, 05:20 AM   #18
502ms
502ms's Avatar
Re: rear sway bar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 06-21-2014, 08:47 PM   #19
PowerdbyChevy79
Re: rear sway bar
nice...so did you pull all the brackets from the fbody and used them on your truck
1966 C10 "Mary"
Old 06-21-2014, 08:56 PM   #20
PowerdbyChevy79
Re: rear sway bar
also..how did you know where exactly to install them...
1966 C10 "Mary"
Old 06-21-2014, 10:23 PM   #21
bonnieclyde100
Re: rear sway bar
yes to the first question and no i didnt know exactly where to mount it but it wasnt hard to figure it out. i just layed it there and slid it back and fourth until i saw where it fit the best.drilled holes in the chassis and in the trailing arms and boltedit up.
Old 06-22-2014, 12:44 AM   #22
PowerdbyChevy79
Re: rear sway bar
thanks for the info brother...
1966 C10 "Mary"
Old 05-30-2021, 01:43 PM   #23
Ricks1971
Ricks1971's Avatar
Re: rear sway bar
We used the rear sway bar from CPP works great! My truck is lowered 2 1/2 in the front a 4 in the back
Ricks1971 is offline   Reply With Quote
Old 06-01-2021, 05:56 PM   #24
CC69Rat
CC69Rat's Avatar
Re: rear sway bar
I used the Hellwig rear sway bar on a GMC I built a few years ago. You can definitely tell its there, but just be forewarned it will cause the truck to be really tight feeling overall, and at times make it feel like it's pushing a little bit. I guess by locking down the rear with the swaybar in place it doesnt allow the front to plant and take a bite (?) Maybe I could have had the front springs too tight .. I'm no pro. I had Hotchkis springs on the truck. All I can tell you is it was on rails. The rear bar is definitely worth the investment if the rest of your truck is setup accordingly.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 06-02-2021, 01:31 PM   #25
HO455
HO455's Avatar
Re: rear sway bar
The 3rd and 4th generation F-bodies use the same rear sway bar with differences in mounting. In addition GM used numerous sizes over the years. This means that not all Trans Am's, IROC's and Z-28's have the same size bars. Some years there were more than one size depending on the various packages offered by GM. That being said the size differences are only 3 to 4 MM of each other for the performance cars so you may not need to search for the absolute largest one.
When I got mine there were 4 to choose from in the wrecking yard. Fortunately I was armed with knowledge and calipers so and I got the largest bar in the yard for my Burban.
RIP Bob Parks.
