Old 06-12-2014, 07:25 AM   #1
1967Bowtie
1967Bowtie's Avatar
Front suspension swap will this work
I am look to upgrade my front suspension on the 67 c20. I know you can swap in the 73-87 a arms to get the better bushings onto the 67 cross member, my main question is there is a swap to change from 8 lug to six lug using 1988 - 95 spindles with lower c20 a arm and c10 upper on a 1967-72, can this be done using the 73-87 a arms on a 67 cross member to get the better ride and get the 6 lug wheel setup. If it will all work do you need a c10 upper and c20 lower a arm form the 73-87 trucks?
1967Bowtie is offline   Reply With Quote
Old 06-12-2014, 11:12 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Front suspension swap will this work
The 88-98 spindle swap has proven to have excessive camber that can't be fixed with a front end alignment.
Search the CaptainFab threads.
Personally I would use the standard 5-lug swap with aftermarket 6-lug rotors.
But just remember most of your 6-lug wheel choices are for the 99-up Silverado trucks,... (unless your order custom offset billet wheels).
They use a wheel with a smaller center bore and much more wheel backspacing.
There is a TON of info on this subject.
If you have trouble searching this site,... search Google.
It will bring you back here anyway.
Keith
Convert to disc brakes.
Old 06-13-2014, 10:07 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
Two easy choices
1. 71 or 72 1/2 ton complete crossmember, direct bolt in
2. 73-87 1/2 ton complete crossmember, drill a couple of holes.
Aftermarket 6 lug rotors as mentioned above if you want to keep 6 lug wheels
Don't get overly wrapped up in trying to mix and match parts front three generations of trucks. You won regret it.
WIDESIDE72 is offline   Reply With Quote
Old 06-14-2014, 12:47 PM   #4
TwinsSpeedShop
I've been down the 88-98 spindle road and I recommend staying away! Find another way.
TwinsSpeedShop is offline   Reply With Quote
