Old 06-12-2014, 02:10 PM   #1
Matthewjb
How to brace cab when installing 1 piece floor
I'm about to install a 1 piece floor pan with all the mounting. Whats the best way to brace the cab to keep the integrity of the cab? Thanks for all the help in advance.
Thanks!
Matthewjb is offline   Reply With Quote
Old 06-12-2014, 09:28 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: How to brace cab when installing 1 piece floor
Thanks!
I'm presuming this is a pickup truck? The reason I ask is that if it is you accidently posted it in the Suburbans and Panel trucks Forum. If that is the case I can move it for you. Let me know....
LockDoc
Leon
Old 06-12-2014, 11:46 PM   #3
Matthewjb
Whoops! Yes your right. If appreciate if you could move it.
Thanks!
Old 06-13-2014, 09:40 AM   #4
LockDoc
LockDoc's Avatar
I cross brace the cab with 3/4 inch conduit, front to back in the door openings, and across the cab, side to side, when doing any major surgery on them.
You can kind of see the conduit bracing in this thread when Ron and I replaced the floor pan and part of the rear panel in his '69 4x4....
http://67-72chevytrucks.com/vboard/s...d.php?t=490272
LockDoc
Leon
Old 06-13-2014, 09:56 AM   #5
boostedc10
boostedc10's Avatar
I am running the braces across the door and one cross-brace.
This is the main area you need to support to ensure that the doors fit correctly when the new floor is welded in.
boostedc10 is offline   Reply With Quote
Old 06-13-2014, 10:01 AM   #6
Matthewjb
Ok, great. Now, I am putting new cab corners, rocker panels, firewall, and the floor. Is there a particular order that is best. I was thinking about doing the cab corners first, then the rocker panels (Just tacking to cab since new floor not in just yet), then the firewall, and lastly the floor. What do yall think?
Old 06-14-2014, 08:00 PM   #7
FlameOut
I'm curious about this myself. I'm about to undertake the same task on my 72 (minus firewall) I was thinkig that if I do both outer rockers, the integrity of the cab should be ok, then I should be able to cut out the rest of the floor and replace with the oe piece floor I bought
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 06-14-2014, 08:25 PM   #8
LockDoc
LockDoc's Avatar
Here are a couple of threads on the subject....
http://67-72chevytrucks.com/vboard/s...d.php?t=574886
http://67-72chevytrucks.com/vboard/s...d.php?t=271066
LockDoc
Leon
Old 06-14-2014, 11:55 PM   #9
jlaird
jlaird's Avatar
Here is what I did. Not the best pictures, but maybe they will help.
jlaird is offline   Reply With Quote
Old 06-17-2014, 10:10 AM   #10
Matthewjb
Thanks for the input guys. Quick question regarding the cab corners.....if Im putting in a new floor should I put the cab corners in before the new floor? Isnt the back of the cab corners tac welded to the back of the floor?
Old 06-17-2014, 10:15 AM   #11
boostedc10
boostedc10's Avatar
I would wait to do the cab corners until you are finished with the floor. They should be plug welded to the rear support brace.
Old 06-17-2014, 07:52 PM   #12
FlameOut
I don't mean to hijack the thread, but I'm doing the same project and didn't think I should start a new thread.
Does the one piece floor need to be installed from the bottom? Like have the new floor bolted to the frame then drop the cab onto it? The one piece floor is heavy and large, and I can't see getting it into the door opening to drop it down into place
1967 Chevelle SS
Old 06-19-2014, 07:12 PM   #13
boostedc10
boostedc10's Avatar
Flameout I did mine with the cab on its back. You don't need to drop it on a mounted floor.
Old 06-19-2014, 08:55 PM   #14
jlaird
jlaird's Avatar
You are on the right track. I would suggest having the floor bolted to a leveled frame and then lowering the cab on it. You will have less of a chance of something moving or not aligned properly if the parts are installed in their final resting place...
