Old 06-12-2014, 07:12 PM   #1
dman1982
dman1982's Avatar
knock sensor question
so i ran my codes today just for giggles and what not, i knew i had a issues with o2 sensors (they where on the manifolds i got from the boneyard and changed them out today) but i got a code for a knock sensor, what does it do? is it important to change out? and i also i got a low temp sensor code whats this from?
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 06-12-2014, 07:34 PM   #2
clinebarger
Re: knock sensor question
Code numbers please.
clinebarger is offline   Reply With Quote
Old 06-12-2014, 07:38 PM   #3
dman1982
dman1982's Avatar
P0128,0135,0155,0327, and 0332
Just a few codes lol
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-12-2014, 08:01 PM   #4
clinebarger
P0128....Change thermostat, Use the correct temp AC Delco thermostat.
P0135, P0155....Bank 1&2 O2 heater circuits, Did new O2's fix this?
P0332, P0327...
1. Disconnect the two pin connector on top of the intake, it has a Light Blue wire & a Dark Blue wire.
2. Ohm each wire to ground. Should have resistance between 93K-107K ohms for each wire.
3. If not in specification, remove the intake manifold and check the connections and wiring to the Knock Sensors (KS).
4. Check for water down in the holes where the KS's are.
Knock sensors play a major role in controlling ignition timing.
Old 06-12-2014, 08:11 PM   #5
dman1982
dman1982's Avatar
P0332, P0327...
as far as 0135, and 0155 the codes havnt come back on yet...its only ran for ten minutes or so since the change
so the ks's are under the intake?
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-12-2014, 08:18 PM   #6
clinebarger
Yes, Under the intake., Is the KS jumper harness plugged to the engine function harness?
Old 06-12-2014, 08:20 PM   #7
dman1982
dman1982's Avatar
ummmmm......IDK...ill go look lol
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-12-2014, 08:24 PM   #8
dman1982
dman1982's Avatar
What am I looking for? Everything that's suppose to be hooked up is to my knowledge, no in plugged connectors
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-12-2014, 08:31 PM   #9
clinebarger
Near the back of the intake.
Old 06-13-2014, 01:12 AM   #10
solidaxel
solidaxel's Avatar
Knock sensors play a major role in controlling ignition timing.[/QUOTE]
Plug that one into memory.........................or where to find it when I need to know!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-13-2014, 03:33 PM   #11
dman1982
dman1982's Avatar
i reset the codes and unhooked the battery, and after changing the o2's the only two codes are 0128 and 0332
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-13-2014, 04:08 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
128 is the coolant operating temp code. Either the coolant temp sensor is wacked/miswired, or its possible that your tstat is stuck open.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-13-2014, 04:16 PM   #13
dman1982
dman1982's Avatar
I'm going to pick up a new thermostat today sometime or tomorrow
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-13-2014, 07:12 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
you can also just whack it with a stick or use a pencil torch to try and heat it up. They can get stuck if they sat with that dexcool in them if it got gooey.
Old 06-13-2014, 07:16 PM   #15
dman1982
dman1982's Avatar
I like your way of thinking...even if you ain't 65 balding fat and living in the parents basement lol
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 06-29-2014, 02:23 PM   #16
dman1982
dman1982's Avatar
well with changing my water pump and dry driving weather i dont have any knock sensor codes...after the water pump change all the codes went away...kinda stoked...must have had some condensation in there
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
