Old 06-03-2014, 09:39 AM   #626
oldman3
oldman3's Avatar
Re: 1968 Chevrolet SWB Stepside Restomod
Originally Posted by SeTx67 View Post
Brian, good to see you back at it. In for updates as they come
Same here...Jim
oldman3 is offline   Reply With Quote
Old 06-03-2014, 06:06 PM   #627
Vic1947
Vic1947's Avatar
Originally Posted by Xeen View Post
I have never done a rear disk conversion (add it to the list of firsts) so this should be fun.
Considering I have to pull the axle shafts I will pray to the truck gods that the shafts aren't worn to the point that they are unusable.
While I'm in there I plan to inspect and if necessary replace parts as needed.
Typically, aftermarket disc brake kits are meant to bolt on so you shouldn't have to modify much. On twelve bolt rear ends, the wear (and/or corrosion) is most often located where the axle shaft rides on the roller bearings. I have a puller for the axle roller bearings if you decide they need to be replaced. I've also seen some homemade pullers on the forum for "once in a lifetime, out in the boondocks" rebuilds where it's more of a PITA to run down a shop tool.
[Popcorn popping] Looking forward to seeing your progress.
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 06-03-2014, 07:48 PM   #628
gdavis
gdavis's Avatar
Thanks George.
I'm an amateur though most of this stuff is new to me so I'm learning as I go and it will be far from show quality when I am finished simply because I don't have the necessary experience to do a restoration at that level, plus I don't really have the patience either haha, my plan all along was to make a nice driver.
I am just throwing a lot of money at it and hoping for the best, we will see how it all comes out.
What do you mean, you don't have the experience? What I seen and the talks we had on the phone tells me different. For the rear brake conversion will be a cake walk compaired to the lS3 swap.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 06-07-2014, 07:37 AM   #629
Xeen
Xeen's Avatar
Hey all;
The fedex man showed up with the good stuff!
Now if I could only get motivated to do the installation that would be great.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 06-07-2014, 09:57 AM   #630
SeTx67
SeTx67's Avatar
I would say to get motivated but it looks like y'all have some nasty weather up there by you.
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435
SeTx67 is offline   Reply With Quote
Old 06-07-2014, 10:24 AM   #631
Xeen
Xeen's Avatar
It's just raining but since the project is outdoors it's a no go.
Old 06-07-2014, 10:29 AM   #632
SeTx67
SeTx67's Avatar
You'll get to it sooner or later. I don't lack much to get mine back on the road and haven't even taken the time to measure for the driveshaft yet.
Old 06-07-2014, 11:41 AM   #633
Blazerowner
Blazerowner's Avatar
Nice build thread. A lot of good info.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 06-07-2014, 12:16 PM   #634
Xeen
Xeen's Avatar
Thanks, I appreciate you stopping by.
Old 06-07-2014, 08:49 PM   #635
gdavis
gdavis's Avatar
I'm glad you got the parts for the change. good luck and it will stop raining soon. so up dates will follow.
Check out Patches
Old 06-09-2014, 08:32 AM   #636
Low Elco
Glad to see you back on the horse!
Low Elco is offline   Reply With Quote
Old 06-09-2014, 12:14 PM   #637
Xeen
Xeen's Avatar
I think the horse is mad at me because it just sits there and glares at me, maybe I should try a carrot on a stick.
Old 06-13-2014, 02:16 AM   #638
Xeen
Xeen's Avatar
Hey all;
After considerable thought I have decided to say to hell with it.
I'm buying an entire new reproduction fleetside short bed for my truck.
After looking at what it would cost to buy a original short bed then repair all the damage it makes more sense from a dollars and cents standpoint to just go with new sheet metal so here soon I'm going to take the plunge and get it ordered.
Yes my wallet will feel the pain but at least I will have close to perfect sheet metal to start with.
I have also decided to put a wood floor in it because they look really nice.
Old 06-13-2014, 05:43 AM   #639
Bennett68C10
Bennett68C10's Avatar
Hey all;
Good decision, I went the same route and bought mine from GMC Paul's but it actually came from SOKY Classics. It fit very good and like you said you start off with perfect sheet metal instead of paying a bunch of money for an original and still having to fix rust.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 06-13-2014, 08:14 AM   #640
mcbassin
Still Learning
mcbassin's Avatar
Nice looking brake kit. Congrats on the bed too. I know it was a tough and expensive decision. I know a few guys that have used them are pretty happy with them. Did you opt for wood floor or metal?
Old 06-13-2014, 03:34 PM   #641
Xeen
Xeen's Avatar
Hey all;
Since I am buying new bedsides the question I am facing is marker lights or no marker lights, decisions decisions...
Opinions on looks vs. functionality anyone?
Old 06-13-2014, 10:41 PM   #642
Bennett68C10
I went no marker lights and also mine came without stake pocket holes too. They are really nice and clean.
Keith
66 Suburban
IG: bennett68c10
Old 06-13-2014, 11:54 PM   #643
gdavis
gdavis's Avatar
Hey Bryan:
You might want to look in crags list I bought mine for 300.00 complete. you might find a bed and that would save you a lot of money. just a thought
Check out Patches
Old 06-14-2014, 06:36 PM   #644
Vic1947
Vic1947's Avatar
I'd agree. I've done both, but prefer the smoother look. Side markers are an additional expense, plus the wiring hassle.
Victor
Old 06-14-2014, 07:46 PM   #645
Xeen
Xeen's Avatar
Hey all;
I took a trip up to Lenexa today and stopped by Bob's vintage trucks and LMC Truck to pickup several parts I needed.
Pictured below is used fleetside Wheel houses, new fleetside Wood bed cross sills, used 1972 rear crossmember with brake hose bracket, and also a very nice condition used rearview mirror, and new side mirrors.
Old 06-14-2014, 09:18 PM   #646
gdavis
gdavis's Avatar
I went with marker lights. I want people to see me from all sides. A Christmas tree can be seen from a distance. but I did shave the holes for the stake bed as you know.
Check out Patches
Old 06-15-2014, 05:30 PM   #647
Xeen
Xeen's Avatar
Hey all;
I've made the decision I'm going to go with 67' bedsides which means I need to sell my 68' front fenders and buy some 67' front fenders.
The 68' front fenders are in excellent condition so it will be no problem to find them a home, the problem will come when I try to find some 67' front fenders that don't need any work.
I also decided to buy the polished stainless steel bed/floor bolt kit.
I will post some pictures when everything arrives.
Old 06-15-2014, 08:30 PM   #648
gdavis
gdavis's Avatar
The only difference between 67 and 68 is the side lights. if I am wrong please tell me.
Check out Patches
Old 06-15-2014, 08:58 PM   #649
Xeen
Xeen's Avatar
That's correct.
Old 06-16-2014, 01:29 AM   #650
sduckworth13
sduckworth13's Avatar
Brian give Bob a call he has the 67 front end. He is asking $250.00 for the fenders. PM me I'd be interested in your 68 fenders.
Scott
sduckworth13 is offline   Reply With Quote
1968, chevrolet, restomod, stepside, swb
