06-13-2014, 11:30 AM | #51 |
Re: Post your best budget mods! ($50 or less)
Several of my plastic clips that support the wiring harness have cracked. I also had several under the dash like this which are hidden from sight, My quick fix was to trim the cracked pieces off, drill a new hole in the orginal tab, and mount with a nylon rivet I bought at autozone. I bought 1/4" rivets and 5/16" rivets to cover the different size holes and trimmed the top of the rivot mount to hide behind original clip.
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle. |
06-13-2014, 09:54 PM | #52 |
06-13-2014, 10:50 PM | #53 | |
We don't count elbow grease time, or else it'd be "post your best mod under $5K"
Project "i'm just going to clean up the interior and the engine bay": http://67-72chevytrucks.com/vboard/s...d.php?t=550931 |
10-02-2015, 11:26 PM | #54 |
bump
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
10-03-2015, 12:42 AM | #55 |
My favorite motor mod on-the-cheap is to recurve the distributor and set up the vacuum advance. Can almost always add some initial timing and get a very nice low end torque and throttle response improvement.
10-03-2015, 05:47 PM | #56 |
Door Checks.
went to the Pick N Pull, found a 2000-ish Jeep XJ and took the front door checks. $20! totally bolt right in, now the doors stay open with the detents, and don't hit the cowl. |
10-03-2015, 08:46 PM | #57 |
Can you post some pics of the Jeep door checks please?
10-03-2015, 08:52 PM | #58 |
But Found Her 25yrs Later!
http://67-72chevytrucks.com/vboard/s...d.php?t=446066
http://www.persh.org/pickup/DoorChecks.htm http://67-72chevytrucks.com/vboard/s...d.php?t=668783
10-06-2015, 01:59 PM | #59 |
I don't have any pics right now, but the links in the post above will tell you everything you need to know. That is where I got my info.
I used the front checks from a 4dr XJ I think it was a 2000-ish, but not entirely sure. |
10-06-2015, 02:35 PM | #60 |
01-20-2016, 10:12 PM | #61 |
Not really a modification, but still a budget fix:
My 65 cab is on a 62 frame. The front cab mounts are located differently. I didn't want to move my existing ones in the event I ever go back to a newer frame. I tried finding replacement mounting washers, but they were rather costly. I found these for $10 shipped. Strut caps. http://pages.ebay.com/motors/link/?n...094604&alt=web . Front Strut Cap Limit Stop Suspension for VW Golf Jetta Passat 1H0412319B
01-21-2016, 12:27 AM | #62 | |
beater 65 gmc at the moment |
01-21-2016, 02:49 AM | #63 |
I painted my friends whole chassis with rustoleum for $50 or less for all the paint..
after I degreased it with diesel fuel then i grinded as much as I could to make it quicker to sandblast , and then I sandblasted it. 1 gallon flat black and 1 quart gloss black and a qt. of acetone less than $50. i sprayed 1 coat flat black with the chassis on its side with the tires still on it , I did the bottom side first. then I dropped it back on the tires to do the rest and get any missed spots . the next day i flipped it up on the other side . then mixed 1 qt gloss with 2 qt's flat black . sprayed the bottom side first then I dropped it back on the tires and finished it up. I didn't think to get any pictures of it after I had sandblasted it . |
04-29-2017, 07:13 AM | #64 | |
04-29-2017, 09:27 AM | #65 |
This will apply to all years. I thought this truck would look better with the wheels painted body color so $7 for self etching primer, $7 for a close match to the body color $4 for assorted sandpaper, and a old green scrub pad we have...
04-29-2017, 09:55 AM | #66 |
All great ideas!
04-30-2017, 11:46 AM | #67 | |
What did you use for a bracket How did you run the tubes? My o/f has a tube in the bottom and one in the lid. I love the look though |
