#301 |
Re: What did you do yo your truck today??
94grounddweller My build thread. http://www.gmt400.com/forum/showthre...ild-on-22-quot |
#302 |
![]() Join Date: Aug 2011
Last weekend I updated my "moonie" to the "needle" instrument panel. Donor truck was a '93 suburban for both the panel and the drac. Used the mod instructions listed plus instrument panel wiring diagrams for both my '88 and the donor '93 plus the ecm diagram for my '88. More soldering than I've done since high school electronics class
![]() http://www.fullsizechevy.com/forum/g...es-w-tach.html ![]()
'88 K1500 Scottsdale 5.7 TBI, 5spd MG5 Last edited by Red88; 06-15-2014 at 06:56 PM. |
#303 |
#304 |
-Justin. The past cannot be edited, or erased. Only accepted. Loud, proud and country by the grace of god! Bradley Anderson 1997-2011 |
#305 |
Plugs, Wires, Cap, Rotor, Intake gasket (upper), all tie rod ends, Idler arm and Idler arm assy, and Pitman arm. So glad to have all that done. Runs like a champ and after the alignment it drives true and straight.
1996 K3500 CCLB. 7.4L auto. 140K. Small lift and exhaust with more to come. |
#306 |
Swapped out my mangled and torn up original seats for a real good set of salvage yard seats from a 1998 Silverado. I figure they must have been hiding under seat covers from new since there isn't even any sun faded sections. Had both of the old seats out back in May when I was repairing the body mounts so swapping in the new ones only took a half an hour - 15 minutes of which was spent trying to remember how to put that center seat belt back together after I took it apart to get it through the small access hole in the seat LOL.
http://www.maritimedragracing.com Atlantic Canada’s #1 source for Drag Racing News, Race Results, Schedules and Track Information. |
#307 |
1999 Chevrolet Silverado |
#308 |
That is a great looking truck.
#309 |
I did some brake work this morning for my dad by replacing both wheel cylinders and a brake drum on his 97 chevy 2-door tahoe. Sadly though I bled the back 2 brakes after my dad lost a bunch of brake fluid from the leaky wheel cylinder and the brake pedal still goes all the way to the floor. I'm leaning towards a master cylinder needing to be replaced at this point. Oh a plus side though, I ordered my 5/7 drop from Belltech for my 93 gmc extended cab truck. It probably won't get shipped out until August 11th though. No big deal though, I still need to order some wheels for it anyways before I drop it.
#310 |
#311 |
Searched for "How to change a tire" and found this:
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" |
#312 |
new wheels
#313 |
Swapped out my rear slider with the leaky plexiglass center section for a factory tinted fixed glass. No more raining in the truck !!! Next up is fix holes in floor caused by the broken slider, looks like 2 about 4" diameter each.
Tim- Bensalem PA |
#314 |
After 315k miles, the upper radiator hose finally blew out a small hole which forced me to replace it lol. Glad it didn't happen on my quick rode trip to OKC for the Buick vs. Ford shootout.
#315 |
My buddy, along with his son, is installing a body lift on his sons truck.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored 1978 Turbo Malibu - Owned since 1986 1987 Grand National Aerocoupe -1 of 1 1988 LeSabre T-Type - Supercharged |
#316 |
![]() Join Date: Oct 2007
changed my trans filter, fluid, and pan. put a 99 factory deep pan on my 97.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
#317 |
New radiator, all aluminum. New rad. hoses. New belt and new thermostat. Next up front brakes, pads and rotors.
#318 |
In the last 2 months on my 89 I've reupholstered my bench seat with vinyl. Installed new upper and lower control arms, front shocks. New master cylinder (NBS) new brake booster. New headlights/ parklights and wiring harness to go with it. 3 color LED taillight bar. Had to put on a new starter. I also replaced the seal and oil in the rear end. I have new door weather seals i need to put on sometime soon and wheel arch trim.
1972 Chevy C-10 1/2 ton longbed project 1989 Chevy 1/2 ton shortbed "If a man does his best, what else is there?" "A pint of sweat saves a gallon of blood"-George Patton |
#319 |
Cleaned the TBI on my 89. Replaced the IAC sensor, O2 sensor and throttle kickdown cable.
#320 |
replaced my starter on my dd 97. went with a gear reduction instead of a direct drive. much better now.
#321 |
I replaced all the brake lines to the rear. I had some 1/4 stainless lying around the shop to go from ABS to rear hose and used coated 3/16 for the rear axle lines. I was backing down a boat ramp when the line let go. That got my attention. I did manage to retrieve the boat with the front brakes working and a low pedal.
#322 | |
#323 |
I will try to get a Pic up tonight.
Bob |
#324 |
painted my new grille
#325 |
Looks like the small Iwata paint gun,I have the same gun and love it. Parts look good ,post an installed pic when done.
