Old 06-15-2014, 12:18 PM   #1
CATCHALLBLUE
CATCHALLBLUE's Avatar
Carburetor setup. What am missing?
Just rebuild a Rochester Monojet pulled off of my '69 C30. Pretty sure the PO had this baby rigged someway and what im not sure of is if im missing any cables/springs. I have a spring with 2 hooks on each end that i cant remember how it was installed. Also there was a thin wire hooked to the choke valve that ran into the cab and tied around the AC controls. Have no idea why.
Thanks for all your great input fellas!
CATCHALLBLUE is offline   Reply With Quote
Old 06-15-2014, 12:23 PM   #2
imjeff
imjeff's Avatar
Re: Carburetor setup. What am missing?
The springs are throttle return springs and get hooked up so they hold the butterflies closed. The other should be the manual choke cable, but should go to a push/pull knob.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 06-15-2014, 12:44 PM   #3
CATCHALLBLUE
I only have 1 spring and as i said cant remember how it hooked up. By "other" do you mean the thin wire that goes into the cab (pic 4)? Not sure this truck had a manual choke knob or where that would be located.
Old 06-15-2014, 12:54 PM   #4
imjeff
imjeff's Avatar
It looks like the spring should go on the rear of your carb from the bracket top (big hole on the angled piece) to the big hole on the carb linkage towards the driver's side. The choke cable (you need to buy one if it's not in tact) needs a bracket near the choke linkage to hold the outside of the choke cable and another piece to attach the actual cable to the choke linkage. I don't have a pic as I'm going by memory from long, long ago, but I'm sure someone will have one.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 06-15-2014, 01:09 PM   #5
CATCHALLBLUE
thanks, thats where i thought the spring went but for some reason doesnt seem right. A lot of tension on the throttle.
Old 06-15-2014, 01:15 PM   #6
imjeff
imjeff's Avatar
Sometimes you can move it around to different holes to get the right pedal feel. I would stop by a parts store and get a double spring set up. I lost a spring on a 63 I had and almost stacked it up. That was when I realized why the new stuff has doubles! Good luck,
Jeff
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 06-15-2014, 01:44 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
I posted some pictures of my I6 linkage in this thread (post #11).
http://67-72chevytrucks.com/vboard/s...d.php?t=456420
LockDoc
Leon
Old 06-15-2014, 02:09 PM   #8
CATCHALLBLUE
Thanks LockDoc that helps but I dont have those holes for the spring to attach to my throttle linkage/bracket. Any ideas where it attaches? Heres a couple more photos.
EDIT: I Have a very similar spring as the one in your post #11 but mine is much shorter.....
Old 06-15-2014, 07:17 PM   #9
LockDoc
LockDoc's Avatar
Not sure where it would go then, Sorry...
LockDoc
Leon
Old 06-15-2014, 07:26 PM   #10
imjeff
imjeff's Avatar
I think it goes on that sheet metal bracket that 45s off the back of your carb. There are a bunch of configurations, but in the end it must pull your linkage back to idle from any throttle position.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
Old 06-16-2014, 02:03 PM   #11
Gruman
Gruman's Avatar
Don't know if this helps bit heres a pic of mine. Its got the rochester single barrel on top of the 292 inline 6.
Heres another one:
Edit: This is off of my C20, not a C30
Gruman is offline   Reply With Quote
