Old 06-16-2014, 11:34 AM   #1
1slo_camaro
5spd swaps
Truck is my 78 long bed. Right now I have in a 700r and its not bad. Its behind a stock 350 with headers and a edelbrock 1406 might have an I.take soon. So maybe 300hp on a good day when the planets are lined up. I had a m21 in one of my trucks and it was great but I don't want linked shifter and I want the extra gear for overdrive.....
So who has done a 5spd swap?
What did you use? I can get my hands on a 10 spline t5... can I use that?
Hhow much $$ did you have invested?
My plans with my truck are simple. Slowly build it on a budget I just picked up a 12 bolt that I'm slowly building up and prepping to go in. And the same with another motor so its all a "in time thing" no rush just wanna make sure its not a setup that'll waste syncros in a most or smoke the clutch in a month but will hold up to a 300-400hp Abc and your typical driving with occasional Saturday night specials
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers
1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles
"Life is full of decisions, we make them and dont look back"
1slo_camaro is offline   Reply With Quote
Old 06-16-2014, 05:08 PM   #2
Ziegelsteinfaust
Re: 5spd swaps
I looked at a swap like this for my F100 project, and there are no car 5 speeds that will last if your going to stomp on it. The truck 5 speeds will last but well shift like a truck.
Aftermarket 6 speeds or the ones from the LT1/LS1 4th gen Camaro will work, but require shifter mods or are quite expensive.
If you plan to cruise the truck or DD with occasional loading a T5 world class will do alright.
Ziegelsteinfaust is offline   Reply With Quote
Old 06-16-2014, 11:07 PM   #3
1slo_camaro
Re: 5spd swaps
I'm not a huge trans guy so where can I find a WC t5?? What did they come in? I have my eye out for a t56 ill throw in and run 2 bucket seats
Old 06-16-2014, 11:28 PM   #4
Ziegelsteinfaust
Re: 5spd swaps
88 and later Camaro's with the V8.
Old 07-13-2014, 12:20 PM   #5
wraprail
wraprail's Avatar
Re: 5spd swaps
I used a T5 from a 1990 Camaro in my 74 C10 for several years with no problems. Pretty straight forward swap. Only the T5's are getting scarce.
My current daily driver is a 85 C10 with a 6 speed (LT1 T56) and its about like my 5 speed swap only with one more gear. Used the same clutch pedal/master cylinder/slave cylinder setup with both transmissions. I'm thinking the shifter hole in the floor was about the same place for both trans and i'm pretty sure I used the same driveshaft with both as well. Best thing I did was get rid of that BORING automatic transmission.
wraprail is offline   Reply With Quote
Old 07-13-2014, 03:50 PM   #6
bdiamond
Re: 5spd swaps
Originally Posted by wraprail View Post
My current daily driver is a 85 C10 with a 6 speed (LT1 T56). Used the same clutch pedal/master cylinder/slave cylinder setup with both transmissions
What did you do for the flywheel /clutch? Will the standard flywheels and clutches that were used for muncies and t10's work ?
bdiamond is offline   Reply With Quote
Old 07-17-2014, 08:06 PM   #7
FritzA
Re: 5spd swaps
Don't forget the A833 option!!! Only a 4 speed but same ratios as the 700r and very strong. Just tough to find but they are out there.
FritzA is offline   Reply With Quote
Old 07-17-2014, 09:39 PM   #8
bluex
bluex's Avatar
Re: 5spd swaps
I'm planning to put a NV3500 in mine buys that's about as far as I've gotten.....
bluex is offline   Reply With Quote
Old 07-17-2014, 11:24 PM   #9
franken
Re: 5spd swaps
A later NV4500 w/ 5.61 1st?
Old 07-18-2014, 09:32 PM   #10
Oldriginal86
Re: 5spd swaps
Will you have to cut the floor and put a hump for the 4 speed O/D to fit? Interested because I'm looking to do the same swap.
Oldriginal86 is offline   Reply With Quote
