Old 06-18-2014, 06:03 PM   #1
faribran
New in tank fuel pump not working
Anyone ever have problems with a in tank pump not priming?
This is a new tank as well as new pump. it has worked about 4 -6 months ago.
Now when the key is turned on you can hear the relay click on then click off.
I checked, with meter, 12.5 volts going to the wire just outside tank.
Any suggestions short of dropping the tank and pulling the pump?
Yes this is an LS1 conversion.
Tks
Rich
faribran is offline   Reply With Quote
Old 06-18-2014, 07:10 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: New in tank fuel pump not working
Pop a different relay in, just to be sure. You can swap that back out, takes 20 seconds.
Then I'd look at the external ground if you have one. After those two easy steps, its pulling the pump out. Are you using the ECM trigger for the fuel pump, or a hotwire of switched +12v?
iirc on the relay its
30- 12v constant
85- ground
87- power to pump
86- fuel pump relay control
If you try to start it, what happens? Is there any change in voltage on the power wire?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-18-2014, 10:45 PM   #3
faribran
ECM trigger, thanks
Old 06-26-2014, 06:29 PM   #4
faribran
Ok, I dropped the tank today, will pull the pump out tomorrow. Any one have suggestions on how to free up this pump?
Old 06-27-2014, 12:47 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Depends if its stuck from sucking something in, or if it arc'd itself.
Old 06-28-2014, 12:22 AM   #6
faribran
I am out of town for the weekend (Mobile, AL). Should pull the pump Monday.
I did notice it is retained by typical locking ring. I have a spare pump in a 2002 silverado.
But this one I am pulling out is basically a new tank and new pump, bought from Spectre Premium. Oh well, will see in a couple of days.
Thanks BR3W
Old 06-28-2014, 10:37 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
NP
Just try and run the pump once in a bucket or something outside of the truck, just to make sure your not junking a good pump.
Old 06-29-2014, 03:07 AM   #8
smoky02
Location: Sunny, Florida, some might call it South Alabama
I hope the pump isn't bad...that definitely wouldn't Bode well for Spectra premium
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 06-29-2014, 12:21 PM   #9
truckdude239
truckdude239's Avatar
i used a spectra premium tank and sender unit in mine but i used an ac/deco ep381 pump in my sender just couldn't bring my self to trust there pumps
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-29-2014, 09:17 PM   #10
faribran
David,
Was your tank made for the F/I pump or did you have to modify? Does it have baffles? Also, tell me about the wiring hook up.
TSS
Rich
Old 07-16-2014, 07:07 PM   #11
faribran
Ok, I took the pump out. Soaked it in pb blaster for a few days. Tested it..it works. Just got finished putting it back into tank and putting the tank back up. Seems to work as it should.
Thanks everyone
Old 07-17-2014, 08:53 AM   #12
smoky02
That's awesome...glad cleaning it out did the trick.
Old 07-18-2014, 12:16 PM   #13
faribran
Thanks bud
