06-15-2014, 09:25 PM | #1 |
Six Luggers- Help!
My Question is about my 69 and it goes like this... Will a 15x8 six-lug fit? I mean will it clear front end components? What's the trick? Is it the back space?
1969 Chevy Stepside |
06-15-2014, 09:33 PM | #2 |
Re: Six Luggers- Help!
I have some 15x8 stock chevy rally wheels off of a early 80s 4x4 and they clear everything. Truck is a 70 c10 short step
06-15-2014, 10:25 PM | #3 |
I am a Referee of life.
Backspacing and hub center diameter are the usual two keys things on this.As long as those and the bolt pattern work.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-15-2014, 11:23 PM | #4 |
Ok then the 4x4s have the large diameter center bore correct? Rally wheels would work for me but but still doesn't the back space have to be right so the wheel dosnt hit the upper ball joint? Do you know the 4x4 back spacing on your Rally's?
06-15-2014, 11:26 PM | #5 |
Ok so the wider the wheel, the sorter the backspace?
06-15-2014, 11:29 PM | #6 |
67-72 parts collector,…
The 73-87 4x4 15x8 rally wheels have a 3-5/8" backspace and will work fine.
Look at ALOT of the 6-lug trucks on the board and you will see this.
06-16-2014, 01:05 PM | #7 |
Will a 4" backspace work? What I am trying to do is learn how to compensate for wheel width to insure proper fit so is there a formula?
1969 Chevy Stepside Last edited by Pflugerman; 06-16-2014 at 02:41 PM. |
06-16-2014, 05:42 PM | #8 |
15" x 8" 6 Lug Rally's (not truck Rally's) all the way around and 275/60/15's on all 4.
06-17-2014, 08:54 AM | #9 |
Nice looking Rally's! Can you suggest a vendar? I need tires before I can get my truck inspected and therefore want some decent wheels forst.
06-17-2014, 05:23 PM | #10 |
They were available thru my local independent Tire Shop. I'm sure if you go to yours, they can order them for you. I bought tires, wheels, GM Flat Caps, Bands, mounted and balanced $1388 w/tax
06-17-2014, 07:30 PM | #11 |
Sounds pretty easy. However I contacted Coker (supposedly the biggest international tire company in the world) and they didn't have any rallys at all that were 6x5.5 bolt pattern. They did have literally 4 steel wheels and 1 primed center with chrome rims on steel wheel. They were willing to make them with a two month wait period. They were willing to custom machine aluminum wheels for 350 each. So.. I guess Ill keep looking unless someone can throw out a vender name for me to try.
06-17-2014, 07:40 PM | #12 |
oem 6 lug, gm wheel, 7 inches wide 225-70-15, 255-70-15 on the rear, had to trim the lower a-frame, other than that cant make them rub. also has the cpp spindles that dont move the a-frame outward.
good luck |
06-17-2014, 08:29 PM | #13 |
Nice! Do you have front disks?
06-17-2014, 08:37 PM | #14 |
yes i have disc (from cpp)and i also choose not to put the power booster and left it manual with new master cylinder, all new brake lines, new shoes on the rear drums and wheel cyl.
had a guy pull out in front of me couple days ago, i was running probably 65-70, got to try out the brakes, really pleased at how fast it will stop! |
06-17-2014, 08:48 PM | #15 |
Look for Wheel Vintiques brand wheels. You can get 15x8's in the correct fitment for about $75ish, plus caps and rings.
06-17-2014, 11:56 PM | #16 |
Hmm... Thanks for the search criteria. Found them at summit.
06-18-2014, 10:42 PM | #17 |
Ok then thanks for the responses. Now if I have six lug pre-71 wheels, then will I have trouble converting to disk brakes?
06-18-2014, 10:53 PM | #18 | |
OEM pre-71 wheels will have interference issue with a disc brake caliper. Wheel Vintiques 6-lug wheels will work fine. Just like 73-87 oem 6-lug wheels,...
