Gm10 bolt handbrake problem (hurry)
I have little problem...i try to connect handbrake cable to my 10 bolt rear (drum brakes,don't have before handbrake).but i don't understand where i put that cable...?
Can anyone help me??? |
Re: Gm10 bolt handbrake problem (hurry)
if you rotate the picture so the pin is at the top, on the right side there should be an arm sticking down with a hook on the end. It looks like that arm is there
The cable goes thru a hole in the backing plate on the left side and hooks to that arm This might help www.youtube.com/watch?v |
Cable goes in thru hole of backing plate and attaches to "hook" on e brake lever # 16
http://67-72chevytrucks.com/vboard/s...d.php?t=481531 |
Sorry guys,i don't still understand...
This is that side what i try do just now... YouTube site not work. |
your Photo is up side down rotate 180 degrees behind lever marked should have "hook" for end of cable
see picture
This is a good link http://www.pbase.com/nufsed/drumbrake
