Old 06-21-2014, 11:05 AM   #1
bighunting
Track arm bushings
Any tips on inserting new track arm bushings? I've got the old bushings out and purchased OEM style rubber replacements from Classic Parts. I was able to insert the trailing arm bushings with an appropriately sized socket and a rubber mallet, but that's not working for the track arm. Will I have to get someone to press them in for me?
bighunting is offline   Reply With Quote
Old 06-21-2014, 12:58 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Track arm bushings
Press makes it easy but a big vise or C clamp and the right size sockets and flat plate would likely work. Just a lot more effort. See if you can find a local shop to press them in.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-21-2014, 03:34 PM   #3
Sharps40
Big bolt, big nut, several real thick washers, grease everything good, couple big wrenches, twist the nuts on the bolts, washers will pull and squish em in.
Can also heat the eye of the track arm and drop the bushing in the freezer before doing the twist and squish.
Sharps40 is offline   Reply With Quote
Old 06-21-2014, 08:21 PM   #4
bighunting
Thank you both. I'll be giving the twist and squish a try tomorrow morning.
Old 06-21-2014, 09:06 PM   #5
Sharps40
Good luck....bushings bout an hour or two in the freezer and warm the track arm eye to ouch temp if you like...but with temps here on the east coast lately, if you put it in the sun for an hour at 2 pm it'll prolly get clear to 200F without even lighting the propane torch!
If ya don't have washers, just drill a hole in a chunk of 1/4 inch or so thick cold rolled steel and use them as washers instead for the twist and squish.
Luck....(chill some beer first, might need it for celebration or consolation, depending on how it goes)
Old 06-22-2014, 09:33 AM   #6
bighunting
Success! Twist and squish came through. But the beer was much needed at the end. Twasn't easy. The first bolt sheered off, and I had to find a bigger one. Got both bushings in though. Thx!
Old 06-22-2014, 09:59 AM   #7
bj383ss
bj383ss's Avatar
What a PITA the stock rubber ones are. I bought the Polyurethane ones. And with the grease supplied everything slipped in by hand.
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 06-22-2014, 10:46 AM   #8
Sharps40
Superb! Now ya won't have to do it again for 47 years!
