01-10-2004, 02:17 AM | #1 |
Blazer bed sides
Hello. Does anybody know if you can buy complete bed sides for a 69-72 blazer or if ones for a swb truck will fit.
Dave |
01-10-2004, 02:55 AM | #2 |
Member since 2000
swb bed side will work, it's has been done.
01-10-2004, 03:07 AM | #3 |
but there will be alot in the process of putting them on the truck
70 longbed 496/th400/Ford 9" |
01-10-2004, 12:45 PM | #4 |
PROJECT 7DEUCE
It would be cheaper $ to buy a lwb and cut the bed side's down to fit the blazer body someone on this site was doing it with there blazer maybe they will step forward??
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-10-2004, 12:50 PM | #5 |
I have had quite a few customers take the shortbed sides and make them work on the blazers.
Longbed Sides you have to cut front and rear to make work. Shortbed only have to modify the front. I have a NOS RH blazer side for $525. Not perfect. Has some small dents in it and some surface rust. Bill
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
01-10-2004, 01:07 PM | #6 |
LWB bedsides would have to be sectioned. SWB would be the best alternative although still a bit of work.
01-10-2004, 01:38 PM | #7 |
PROJECT 7DEUCE
The only reason I was suggesting lwb side's is I rarely ever see a swb for sale here in oregon and if it is for sale it's attached to a truck... Unless you can afford to buy new swb side's and cut em down the lwb would be a cheaper route even though it would require more work.
