Old 06-22-2014, 12:26 AM   #1
Project86
Exclamation headlight issue after cab swap
real quick as to not get anyone confused...
i bought an 81 swb with quad headlights. all worked fine
i bought an 86 swb because the cab and bed were in better condition than my current 81.
My 81 had the headlight dimmer on the floor.
86 has it on the column.
after the swap and everything (which was done roughly a year ago, and the truck runs fantastic since rebuild)
when i turn my headlights on, just the high beams stay on. (the upper headlights)
when i try moving the stick on the column, to turn on my high beams or to switch between the two, the stick doesnt *click* ??
is that an issue with the signal lever on the column itself??
also when i go to use any turn signal, only the rears flash as if i had my hazards on
Project86 is offline   Reply With Quote
Old 06-22-2014, 12:33 AM   #2
rich weyand
rich weyand's Avatar
Re: headlight issue after cab swap
Did you re-connect the cab ground from the engine to the firewall when you swapped cabs?
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 06-22-2014, 12:35 AM   #3
Project86
i actually replaced it. with a thicker gauge wire, and even used a wire wheel to clean the metal.
i have it attached to a bolt location on the firewall to near where the frame rail is.
since i kept everything from the front end, all my wire harness plugged right in to the ports on the firewall
Old 06-22-2014, 11:19 AM   #4
79Betty
79Betty's Avatar
My 85 has a limp stick for a turn signal as well. Turn signals worj good nall but brights won't. Down the column on the left side is where the switch went. Try pressing on it by hand. If the headlights dim or go brighter or w/e then it's in the column. If not probably switch itself. Idk how to fix the turn signal lever though haven't got that far lol.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 06-22-2014, 07:10 PM   #5
hatzie
Moderator
hatzie's Avatar
New AC Delco Dimmer Turn Switch is not expensive.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
