Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 06-22-2014, 11:09 AM   #1
epon
epon's Avatar
Compressor Motor Sparking on Start
Wondering if this is normal on start up, motor is a baldor:
https://www.youtube.com/watch?v=z5lSbCYuRtc
TIA
'82 C-10 SWB / C'd, Z'd, Body'd and Bagged / Shaved firewall, wiper cowl, drip rails, stake holes and tailgate/ 20" & 22" Milanni Voodoo
'81 C-10 SWB Parts Truck
IRC - http://webchat.snoonet.org/#baggedtrucks
epon is offline   Reply With Quote
Old 06-22-2014, 12:12 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Compressor Motor Sparking on Start
yes
Old 06-22-2014, 12:14 PM   #3
epon
epon's Avatar
thanks!, can def. see why one wouldn't want to be making fogs of paint around these things.
Old 06-22-2014, 02:38 PM   #4
_Ogre
_Ogre's Avatar
single phase motors have a start winding and switch, the switch is centrifical; closes when the motor stops and opens after a certain rpm
the start winding gets the motor turning in the correct direction and then opens the switch
the opening of the switch is what your seeing
and no, you wouldn't want to use it in an explosive atmosphere as you can also see a spark at your pressure switch
shop air compressor timer
Old 06-23-2014, 10:35 AM   #5
ERASER5
ERASER5's Avatar
One thing to check is if your bleed off switch is working as well as your check valve. The bleed off should hiss at shut down and if the check valve works, the hiss will stop after a few minutes. If the hiss does not stop, then the check valve is bad and the compressor will start up under full load. This causes significantly more start current and strain on the compressor.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 06-23-2014, 10:37 AM   #6
epon
epon's Avatar
hiss stops shortly after the compressor stops
