Old 06-22-2014, 12:32 PM   #1
AirSpeed
AirSpeed's Avatar
Fuel pump, vapor lock? My truck died on the hi-way.
Yesterday after a long three days of new car shopping I was headed home, about an 80 mile trip and my 72 GMC started cutting out and finally died on the side of the road. It's a 72 4X4 with 350/350. It was a hot day, about 106, truck was running cool but suddenly would run out of fuel and die. The fuel filter was empty, no gas. After a while I tried to start it and it fired right up, ran fine. I had a tow truck on the way so I decided to take the tow home just in case it happened again. When we took the truck of the tow truck I could smell gas really bad in the cab, I occasionally got a wiff of gas in the past but this was like someone dumped a cup of gas in there. I let it air out and the truck started right up, there was no gas on the bed of the tow truck or anywhere in the cab that I could find , nothing dripping under the truck, I'm at a loss. Any ideas what and where I should start looking?
AirSpeed is offline   Reply With Quote
Old 06-22-2014, 12:59 PM   #2
ho70
ho70's Avatar
Re: Fuel pump, vapor lock? My truck died on the hi-way.
My truck did in way to work yesterday as well, turned out the in carb filter was clogged solid. Some posts on here have mentioned big block fuel pumps shut down when hot. I would also clean the fuel gauge pick up sock in the tank
ho70 is offline   Reply With Quote
Old 06-22-2014, 01:07 PM   #3
geezer#99
geezer#99's Avatar
Do you have a vented gas cap?
Old 06-22-2014, 01:07 PM   #4
PowerdbyChevy79
PowerdbyChevy79's Avatar
To me ..it sounds like you may have some sort of vapor lock going on...your truck has (should have) the vent line for the gas tank that runs up the passenger side of the cab..I would start there
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 06-22-2014, 01:12 PM   #5
AirSpeed
AirSpeed's Avatar
Thanks, I actually pulled the tank out when I painted my truck, cleaned the pickup tube screen too. The fuel pump is only a couple years old and seems to be working fine. I took the filter out of the carb years ago and replaced it with an inline filter which is clean. Seems odd that I had such a strong smell of gas in the cab but nothing's leaking. I'm really hoping I find the problem, it's running fine now but I don't want to get stuck on the side of the road again. Thanks again.
Old 06-22-2014, 01:29 PM   #6
davischevy
davischevy's Avatar
Check the fuel line from the pump to the carb. If its touching anything, even slightly it can cause a vapor lock in hot weather, especially with ethanol gas.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 06-22-2014, 01:53 PM   #7
pwdcougar
pwdcougar's Avatar
What kind of carb to intake gasket are you using? Had a problem with heat transfer from the intake to the carb and it caused vapor lock. A thick insulating spacer type carb gasket solved the problem.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 06-22-2014, 02:13 PM   #8
AirSpeed
AirSpeed's Avatar
Paul
It's a quadrajet, thick gasket underneath. The fuel filter was bone dry, no fuel coming through at all. Can a vapor locked carb stop fuel from flowing from the pump to the filter and carb? I have a transparent filter and after awhile could see tiny amounts of gas getting "sucked" through it but wouldn't fill up. I just got back from driving it and it's running fine. The gas smell in the cab is also gone.
Old 06-22-2014, 04:48 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Did you check the rubber fuel line under the cab? It may be cracked or have a hole in it. There is also a vent line in the cab that loops up on the passengers side by the rear window. That may be where the gas smell is coming from.
LockDoc
Leon
Old 06-22-2014, 04:59 PM   #10
leftybass209
leftybass209's Avatar
Yeah, you shouldn't be able to smell any fuel in the cab. I swapped my 71 tank for the 69 tank to get rid of that vented hose as it's one more thing to deteriorate. That is a good place to start.
leftybass209 is offline   Reply With Quote
Old 06-22-2014, 05:58 PM   #11
AirSpeed
AirSpeed's Avatar
LockDoc
They looked in good shape when I put the tank back in but that was five years ago so I imagine they could be bad now. Do you see any reason that would prevent fuel from getting to the carb but not leak any noticeable fuel anywhere, other than the smell? Could the venting system allow air into the gas line but not allow fuel to leak out somehow? I've looked at a schematic of the vent and fuel line routing and can't picture how that could happen but I'm exhausted and might not be thinking straight! Thanks for the suggestion!
Old 06-22-2014, 05:59 PM   #12
AirSpeed
AirSpeed's Avatar
Does it vent out the cap or?
Old 06-22-2014, 06:32 PM   #13
LockDoc
LockDoc's Avatar
A hole or crack in the fuel line under the floor could suck air and prevent the fuel from reaching the pump, and a crack in the rubber line on the vent tube could leak fumes into the cab but neither one would affect the other....
LockDoc
Leon
Old 06-22-2014, 06:39 PM   #14
AirSpeed
AirSpeed's Avatar
LockDoc
I'll check them out in the morning, probably replace them anyway as I'm sure they're the originals. Now I have to drain 20 gallons of gas out of my tank! Hope I have enough gas cans.
Old 06-22-2014, 06:59 PM   #15
john
member #16
john's Avatar
Just unscrew the line from the tank sender and break the suction.
john is offline   Reply With Quote
Old 06-22-2014, 10:35 PM   #16
slikside
slikside's Avatar
LockDoc
I had some strong vapor smells in my cab once in a while. It was the original rubber hoses in cab for the vent as LockDoc says. Since I've replaced them, I haven't smelled a thing.
Can't see that causing fuel starvation though. Fuel pump going intermittent??
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 06-22-2014, 10:51 PM   #17
AirSpeed
AirSpeed's Avatar
I'm going to check the lines tomorrow. I don't know if a mechanical pump could work intermittainly, is that possible? I replaced it two years ago, I guess it could be getting worn but it seems like it would either work or not.
Thanks!
Old 06-24-2014, 12:29 PM   #18
AirSpeed
AirSpeed's Avatar
I'm going to replace my rubber fuel lines in the cab and under my truck today, I'm seeing a lot of black particles in my filter, I'm assuming it's deteriorated rubber breaking away inside the gas line, I can't think of anything else that would be black in there, anyone know what size line was used on these trucks in 1972? I drove my truck about twenty miles yesterday, ran perfect till I got two miles from home then it died again, luckily it was downhill all the way to my driveway.
Old 06-24-2014, 01:43 PM   #19
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
My guess is fuel pump.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 06-24-2014, 05:15 PM   #20
hotrod68c10
hotrod68c10's Avatar
the tank can pressure up due to heat and if your vent is clogged it wont depresurize until the pressure gets high enough then its probably blowing the pressure out of your vent line into your cab then the truck starts because the pressures gone
hotrod68c10 is offline   Reply With Quote
Old 06-24-2014, 05:28 PM   #21
midniteblues
midniteblues's Avatar
it sure does sound like the rubber fuel hose collapsing under suction.
the ethenol in the gas nowadays destroys the rubber quickly from the inside out.
also use a flashlight and check inside your tank for crud or the source of your black particals
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 06-24-2014, 05:40 PM   #22
AirSpeed
AirSpeed's Avatar
Well I pulled my tank, dumped it out, found the screen on the pickup tube had deteriorated, the lines were full of little pieces of it. I replaced all the gas line with new, added a big filter inline under the truck where the gas line comes through the floor, changed the filter and line on the carb and the fuel pump. I didn't see any real issues with the gas line other than it being old and starting to crack but it's all new now. After all that I fired the truck up, it ran for about 40 seconds and died. No gas getting to the carb filter. All I can do now is replace the fuel pump, of course my local NAPA didn't have one in stock so I won't know if it's the ultimate problem or not until tomorrow when it arrives! Any ideas what I could have missed? I'm hoping it's the fuel pump and if so I hope the new one last more than 10 months!
Old 06-24-2014, 10:35 PM   #23
LockDoc
LockDoc's Avatar
Did you blow all of the lines out with air pressure while you had it apart? Mine had a lot of solid gunk in the steel lines. I used an old speedometer cable (the inner part) and rodded my lines out then used the air hose and blew them out good. I got a lot of junk out of them....
LockDoc
Leon
Old 06-24-2014, 11:02 PM   #24
AirSpeed
AirSpeed's Avatar
LockDoc
Yep, then I injected a half gallon of gas through the line starting at the tank to the pump, I disconnected the pump end and let it drain into a bucket, there was still some crap in the line but it finally cleared up. Tip to anyone doing this, don't try a funnel! I ended up using a big syringe stuck in the line, wish I'd thought of the speedo cable, I just happen to have one! I'll keep that in mind next time I need to clean a tube like that, great tip! I don't know if it's possible but I'm thinking that some of the rotten screen on the pickup tube could have plugged up the valve in the pump, that or the pump just wore out fast. I'll have a new one tomorrow. Either way it feels good knowing all the gas lines are new and safe! Now I have to remember I installed a second filter under the truck. Thanks!
Old 06-24-2014, 11:34 PM   #25
LockDoc
LockDoc's Avatar
No problem. Keep us informed on the outcome for future reference.
LockDoc
Leon
