Old 06-22-2014, 04:22 PM   #26
leftybass209
leftybass209's Avatar
Re: Wood Type for new bed
Originally Posted by skorpioskorpio View Post
Rosewood huh? Hey you might as well go for ebony or ivory, real rosewood lumber is virtually non-existant. You'll be hard pressed to find it much thicker than a few sheets of paper or solids much bigger than enough to make a pen. Teak, walnut and mahogony are firewood in comparison.
I Don't know if you are making your remarks about illegal Brazilian rosewood but I just priced indian rosewood at 130-150 a plank, and my father-in-law orders it for furniture projects. I don't have an immense knowledge of wood but that's what I know is available and an option I'd use. It's just an opinion, much like yours and anyone elses.
leftybass209 is offline   Reply With Quote
Old 06-22-2014, 05:57 PM   #27
skorpioskorpio
*East* Indian Rosewood, Brazillian Rosewood, Madigascar Rosewood, Burmese Rosewood, basically all the species that were traditionally considered Rosewood by furniture makers are all endangered or vulnerable and most illegal to export from their native lands. These are the rosewoods that have the desireable deep colors, high contrasting grains that polish up like glass making them highly sought after for centuries for everything from furniture to trinkets. These trees take over a 100 years to mature. Sheesham (Indian Rosewood) on the other hand is fast growing and until recently was grown for firewood, not really the same thing.
skorpioskorpio is offline   Reply With Quote
Old 08-15-2014, 03:12 PM   #28
68c10airstream
68c10airstream's Avatar
I've picked up black locust, it looks like ash and tough as nails. It's also known as ironwood if it was told to me correctly. Black locust is traditionally used for fence posts and exterior projects. After 60-80 years with no finish it is pulled from the ground and maybe 1" of rot and still useable. A fellow i met told me this, when the lumber is green you can nail it, but once dry you need to drill first. I visit my father in southern minnesota and found a dealer that had a complete pallet of ironwood so we selected more than enough to do the bed and a couple of Adirondack chair projects. The real beauty was all of the lumber came from the same tree (flitch) so i can bookmatch the boards during installation. Boards cost around $3.25 a board foot rough sawn 1" thick. Honey locust is a similar species but no where near the durability and didn't care for the pink hue.
68c10airstream is offline   Reply With Quote
Old 08-15-2014, 07:30 PM   #29
Econman
Econman's Avatar
Personally, I'd probably try hickory. The grain is amazing.
Econman is offline   Reply With Quote
Old 08-15-2014, 07:49 PM   #30
davepl
davepl's Avatar
Oak. I also recommend semi-gloss as gloss really only looks good if you're going to color sand it.
Even the semi-gloss I sanded out to 1000 (or 1500) before final coat. Probably not required but this is the first woodworking I've ever done (well, the bottom side was technically first, that's where I practiced).
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-15-2014, 07:51 PM   #31
davepl
davepl's Avatar
While I'm at it, if I had to do it over again I probably would have had my original bed strips chromed. While you can imagine I won't be hauling a ton of debris in there it's still going to be work to maintain stainless.
And I should have tubbed it and put in dualies :-)
Probably $500 bucks at least though. I forget what the stainless ones cost.
Another tip: the ends are where the boards will rot and fail. Don't be shy about putting extra coats on the ends.
