Old 06-24-2014, 11:00 PM   #1
chewychevy67
anyone have a 4G/4GC 283/327 rochester carb with A.I.R. 66-67
If anyone has one I would like to know where the hose from the diverter valve hooks to the carb for vacuum signal? A picture would be great. Thanks, Rod.
chewychevy67 is offline   Reply With Quote
Old 06-26-2014, 01:25 PM   #2
chewychevy67
Re: anyone have a 4G/4GC 283/327 rochester carb with A.I.R. 66-67
anyone with a 67 factory smog truck or 66-67 smog car 283 engine? here is a pic of a carb without smog. just need a pic of one like this with smog. even a 2 barrel just so I have an idea of where to hook it up.
Old 07-02-2014, 04:53 PM   #3
chewychevy67
nobody?
Old 07-02-2014, 05:01 PM   #4
lha1992
lha1992's Avatar
Hmmm talk to member cortcomp (if that's how you spell it) over in the 60-66 section. He's doing a full blown restoration on his 66 factory 327 an powerglide truck which was a Cali truck with smog an he might be able to help.
lha1992 is offline   Reply With Quote
Old 07-02-2014, 05:15 PM   #5
chewychevy67
I have already but thanks for the help. He wasn't able to help me.
Old 07-02-2014, 05:58 PM   #6
chewychevy67
here is a picture of the valve and hose. I have no port on the carb for it and it wouldn't reach if I had one. Carb may not be a California carb though. I suspect this goes to the back of the carb but unsure.
Old 10-22-2014, 10:33 AM   #7
chewychevy67
Ttt
Old 04-26-2015, 12:06 PM   #8
chewychevy67
Anyone
Old 04-26-2015, 01:41 PM   #9
toms68cst
toms68cst's Avatar
I have a Rochester 4b AIR diverter valve smog hook up on my 68 if that helps. Are they similar?
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 04-26-2015, 01:44 PM   #10
toms68cst
toms68cst's Avatar
I was troubleshooting my AIR system a few weeks ago and found this site helpful.
http://www.camaros.org/emissions.shtml
Old 04-26-2015, 03:16 PM   #11
chewychevy67
I have a Rochester 4gc carb so I am not sure where on that carb the hose hooks up. 68 and on has a Quadra jet . Similar but different.
Old 04-26-2015, 08:46 PM   #12
toms68cst
toms68cst's Avatar
My diverter valve connects under the choke vacuum thingy. You are right, I have a Q-jet.
Old 10-13-2015, 07:40 PM   #13
chewychevy67
Put this back out there
Old 10-13-2015, 08:55 PM   #14
jayoldschool
Moderator
Would my 65 Impala 327 4GC have what you need?
jayoldschool is offline   Reply With Quote
Old 10-13-2015, 09:24 PM   #15
toolboxchev
Stock is good, but I would rip that smog stuff outta there.
toolboxchev is offline   Reply With Quote
Old 10-13-2015, 10:27 PM   #16
chewychevy67
If it has a 4g or 4gc it would. If you could post a picture of the carb where this hose connects or even take a few of the whole A.I.R. system I would appreciate that.
Old 10-15-2015, 05:31 PM   #17
racerop
racerop's Avatar
As far as camaros were concerned http://www.camaros.org/emissions.shtml 66-67 didn't use a diverter valve, they were not used until 68.
racerop is offline   Reply With Quote
Old 10-15-2015, 05:42 PM   #18
chewychevy67
You are correct it is a mixture control valve. It still needs vacuum signal though.
Old 10-15-2015, 10:58 PM   #19
sodly
sodly's Avatar
Got a '66 327 with a 4G.... but no smog pump.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 10-16-2015, 11:03 PM   #20
Steeveedee
Who Changed This?
Steeveedee's Avatar
You might try finding someone with a repair manual for your year truck, if you want it all original to include the smog equipment. Most people just gut the system, as in those days it was California only. The other 49 states did not use this (except sometimes New Jersey and Colorado). It was used to supply air to the exhaust during warm-up to further combust the rich mixture until the choke opened. There was a thermostatic switch by the thermostat, and in some cases, actually mounted to the thermostat housing. If that thermostatic switch is gone, that AIR system doesn't work, anyway. Anyway, the vacuum line would go to the thermostatic switch, which was connected to full manifold vacuum.
Let me see a pic of the front of the engine, especially the thermostat housing and the front of the intake manifold. I'll see what I can dredge out of the 30 year old memories. I was a smog mechanic in those days, but it's been a long time.
~Steven
Simi Valley, CA
Old 10-17-2015, 10:46 PM   #21
chewychevy67
Here are the pic's. This is not the original carb to the A.I.R. system. That's why I don't know where the signal comes from. I de-veined the pump so the system won't function ( it now has the correct carb and distributer for non smog 327) but the reason I want to know the location is so it looks correct and functionable
Old 10-18-2015, 05:27 PM   #22
Redline novdog
Redline novdog's Avatar
Wow I feel fortunate,I didn't know they had emission stuff back then !
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 10-18-2015, 07:36 PM   #23
stsalvage
Scrapper 1
stsalvage's Avatar
that is called a 4V carb some came on Corvette some came on 1963-67 car's and trucks
1966 was the first year of smog and seat belts and smog pump and air tubes
stsalvage is offline   Reply With Quote
