Old 01-10-2004, 05:35 PM   #1
gotmud
gotmud's Avatar
IT CRANKED!!! But Its backfiring...
Got it all back together and git it to crank and run a few moments. It is backfiring out the carberator. What do I need to do? Is advancing the timing mean turning it counterclockwise or clockwise?
SOUNDS GOOD with just the ram horns on it!
Glenn
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 01-10-2004, 05:55 PM   #2
rage'nrat638
rage'nrat638's Avatar
you more than likely need to retard it ....turn it clockwise
rage'nrat638 is offline   Reply With Quote
Old 01-10-2004, 05:57 PM   #3
Rooster's 67
Rooster's 67's Avatar
what did you have to put back together? haw far tore down was it?
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-10-2004, 05:58 PM   #4
Oborny71
Oborny71's Avatar
normally it means your timing is off. could be a vacumm leak also. Did you just get done building this motor or? Your distrubutor might be off 180 degrees. CAUTION: if you are running just ramhorns with no exhaust system behind it, do not run your motor more than a minute or two. the cold air will travel up there and warp your valves!
67 Chevy SWB - goal of a 1,000 hp weekend cruiser
Oborny71 is offline   Reply With Quote
Old 01-10-2004, 06:05 PM   #5
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
...or even break them.
Cat Fuzz is offline   Reply With Quote
Old 01-10-2004, 06:16 PM   #6
gotmud
gotmud's Avatar
Total rebuild. Bored 30, new heads, pertronix replacing points in stock distributor, new intake, new 4bbl carb. I guess this makes it all simple huh....
I turned the distributor counter clockwise say from 8 oclock to 7 oclock and the back firing stopped.
Ill set the timming later now that the breather is finished burning.
Now I got to get the manual choke cable replaced so I can drive it.
Any tips on how to get the choke cable off???...I have to replace it with a longer one....
Thanks for the tips and Ill put the tubes on the ram horns next also.
Glenn
Glenn
Cumming, Ga
