Old 06-27-2014, 11:22 AM   #1
Jon01
Jon01's Avatar
PB Trailing Arms + Parking Brake
Those of you with PB trailing arms, what are you doing for a parking brake?
There are no tabs on the arms to feed the cables through like the stockers have.
I thought about cutting the tabs off of the stock arms and tigging them to the PB stuff but if you guys have a different idea I'm all ears.
Thanks,
Jon
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 06-27-2014, 03:20 PM   #2
big d's red67
big d's red67's Avatar
Re: PB Trailing Arms + Parking Brake
I did away with my e-brake.
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 06-27-2014, 09:32 PM   #3
2002yanks
Thats what i did. Cut them off the old and welded them to the pb ones. works great. Cant eliminate them in ny(have to work to pass inspection).
My build thread!! http://67-72chevytrucks.com/vboard/s...d.php?t=474018
2002yanks is offline   Reply With Quote
Old 06-28-2014, 12:11 AM   #4
Gipper01
Gipper01's Avatar
You should be able to work out something with the shaft collars from McMasters. Do a search on the forum regarding how some members are attaching the wheel sensors from Accuair to the tubular trailing arms using the shaft collars; you may find this to be a more reasonable option for mounting the rear parking brake cable to the tubular trailing arms. No welding required - just a little ingenuity.
Gipper01 is offline   Reply With Quote
Old 06-28-2014, 12:25 AM   #5
Gipper01
Gipper01's Avatar
You should be able to work out something with the shaft collars from McMasters. Do a search on the forum regarding how some members are attaching the wheel sensors from Accuair to the tubular trailing arms using the shaft collars. Simply type "shaft collar" in the search engine, select the 67-72chevytruck.com radio button and select the goggle option. You may find this to be a more reasonable option for mounting the rear parking brake cable to the tubular trailing arms. No welding required - just a little ingenuity.
Old 06-28-2014, 02:11 AM   #6
jtp67-72
jtp67-72's Avatar
Here u go...used the larger ones on trailing arms for accuair but I'm going to use them for e-brake cables..just drill and tap..install bolt and bracket for cable...jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
