06-27-2014, 03:55 PM | #1 |
69 K10 Left Over Parts
If a forum member needs any of this stuff, let me know ASAP. It will be going to the scrap yard soon. No pics, no shipping so don't ask. If you don't know what it is you don't need it. All items were working when removed from my 69 K10:
closed knuckle front axle FREE 12 bolt non-posi rear axle FREE front and rear stock springs FREE Heavy ass steel rear step bumper FREE Manual steering gear box FREE Front Crossmember FREE Stock fuel tank FREE Manual brake master cyl. FREE 283 SB Engine $100 Clutch, PP, Bellhousing, all brackets, linkage, etc. $50 Rockwell T-221 T-case, shifter, and adapter $75 SM 465 Tranny and shifter $75 Must be picked up 20 mi. SW of OKC, bring help to load. Also for sale, will ship USPS for cost: T-Case crossmember and mount brackets $100 Manual high hump $100 New black poly 4X4 cab and rad support mounts, no hardware $50 You can PM me but I don't check the forum every day. Text or call 405-397-3927
69 K10 SWB Project Dream '69 2011 K2500 Silverado Beat to fit, Paint to match Dream '69 Build Thread |
06-30-2014, 09:57 AM | #2 |
Re: 69 K10 Left Over Parts
I am interested in the T-221. 10 spline coupler included- what condition is the coupler and input shaft in? Also are there locking hubs on the front axle and could I be luck enough for them to be the metal originals? Thank you, Bruce
06-30-2014, 11:20 AM | #3 |
Carpe manana
Interested in cab/rad mounts - stock height, pics?
07-01-2014, 01:08 PM | #4 | |
The tranny and T-case are still bolted together right now. I was going to leave them together in case someone wanted them both. Everything was working fine when I parked it and it has been stored inside the entire time. If you decide you want the T-case I will help you seperate them when you come to pick it up. There are no locking hubs on the front axle, they were aftermarket and I am keeping them. The axles have been outside for about 4 months but I just took the locks off of them two weeks ago.
07-01-2014, 01:11 PM | #5 |
They are poly aftermarket replacements, so not a body lift. I will try to get some pics this evening.
07-01-2014, 06:40 PM | #6 |
Carpe manana
Thanks - looking at another K10 so may have need if set complete. Thanks. Pete
07-03-2014, 01:16 PM | #7 |
Haven't forgotten about you, just been busy at work. I will try to get some pics posted soon. Once I get out there and start looking around I might have some other left over parts you might need as well, so I will get pics of everything and revise this post.
07-03-2014, 11:17 PM | #8 |
Carpe manana
No prob, I understand. Post when poss and thanks. Pete
07-08-2014, 08:52 PM | #9 |
Sorry it took so long to get the pics up.
Prothane cab mounts DeadheadNM is first in line This set of radiator support mounts is from LMC, they are either poly or VERY hard rubber and don't have the shiny surface of the Prothane cab mounts. Also found this set of 73 & up engine mounts with a new set of ARP bolts for $30 shipped. EDIT: Actually, the mounts are 67-72, it is the bolts that are for 73+ trucks. This VDO universal fuel sender kit is brand new from Jegs. It comes with the gasket and a split ring to weld into a fabbed up tank. It uses the 5 bolt offset pattern and is 0-90 ohm for our trucks. Decided to go a different direction on my project so I don't need it. This is only the second time it has been out of the box. I will take $30 shipped if someone can use it. This is a new 4X4 with AC repop shroud from LMC. I decided to move my engine forward so it won't fit in my truck now. I will take $50 if someone can pick it up. I don't have the box anymore, so don't know if I can ship. It may be considered oversize as well. I no one locally wants it I can check on getting it packaged and shipped through UPS. Let me know.
07-08-2014, 09:13 PM | #10 |
Carpe manana
If the rad/cab mounts are correct for 4wd I'll take them pending ship costs to 59901. Thanks for the pics, Pete
07-08-2014, 10:15 PM | #11 | |
http://www.suspensionconnection.com/7-103c4.html It looks like $11.30 for a USPS medium flat rate box is the best option for shipping.
07-08-2014, 10:39 PM | #12 |
Carpe manana
Thanks - will have to pass until I'm able to check those on my K20 (not here at home) for comparison. Don't want to delay a possible sale if someone else interested.
07-30-2014, 01:36 AM | #13 |
Looking for a Drivers Side [LH] Front Leaf Spring Hanger for a '71 GMC Jimmy. [K/1500 = K/5, K/10]. Shipped to 85704.
07-30-2014, 08:16 PM | #14 |
Sorry, I reused the spring hangers.
07-31-2014, 02:53 AM | #15 |
Thank you for your time.
07-31-2014, 11:14 AM | #16 | |
Still Learning
