Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 06-29-2014, 03:48 PM   #1
jumpsoffrock
Which distributor to use for HEI swap on '67 327
I have read this write-up: http://67-72chevytrucks.com/vboard/s...ad.php?t=13698
I have also spent hours searching google and read countless other threads and write-ups on this subject of converting late 60's SBC's from points to HEI, on every vehicle platform known to man.
I still have one rather important question I have failed to understand though, how can I physically tell which HEI distributors will correctly install and bolt up to my engine--just by looking at it?
Are they all the same and will all work as long as they don't have the "four wire plug"?
Quote from write-up I posted a link to:
Fast68Chevy: any HEi distributor on any chevy V8 without the extra 4 pin flat wiring plug will work, make sure it has the vacuum advance diapragm on it
There is a 1978 Chevy van in a local junkyard with an intact HEI, full setup with Vacuum advance just begging me to scoop it up, but I don't want it if it won't work for me.
Thank you very much.
jumpsoffrock is offline   Reply With Quote
Old 06-29-2014, 04:29 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Which distributor to use for HEI swap on '67 327
You got it, the new four wire plug won't work, but the older ones will. The 78 van should work just fine.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-29-2014, 04:32 PM   #3
jumpsoffrock
Alright! I might just go do that today! Thank you very much.
Old 06-29-2014, 04:48 PM   #4
C10 - C90 Bill
C10 - C90 Bill's Avatar
As much as I am an old Points man, I know the early HEI's were problematic. Not sure the exact year they got improved though.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 06-29-2014, 05:36 PM   #5
Softpatch
Softpatch's Avatar
I'm a big fan HEI
the early one had issues were with the Brain and the china stuff off ebay
the drive gears are not sturdy and wear out
Which one to get.?
if it has a vacuume can on the side thats the one to get also pop the cap look at the inside top of rotor ware is good...... Realy dirty inside ...PASS
there called "One wire" because litrally just plug one wire to the block on side of cap tp battery your good to go( ignition switch)
the other hole is for the Tach hook up
Please note the shaft in the picture thats what they look like long ...Sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 07-24-2014, 11:48 PM   #6
colgad
colgad's Avatar
Swap the dist gear off of the original to your new HEI. The intermediate shaft is different on these engines.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 07-25-2014, 12:04 AM   #7
Softpatch
Softpatch's Avatar
how so.?
Old 07-25-2014, 12:24 AM   #8
JonnyC10
Subscribed.
JonnyC10 is offline   Reply With Quote
Old 07-25-2014, 12:37 AM   #9
jumpsoffrock
Yes, I'd definitely like to know, I've not heard of anyone doing this in the many other HEI swap in a SBC threads.
I got a unit from the junkyard and will install it soon-ish....most likely before end of summer.
Old 07-25-2014, 08:16 AM   #10
colgad
colgad's Avatar
Originally Posted by Softpatch View Post
how so.?
On my 72 C50 with a 350 the Dist Gear had a female slotted gear.
Normal SBC's have a Male gear end. The normal intermediate shaft has male for the oil pump and female for the dist end.
Mine had a Male Male configuration. (really, I am not making this stuff up) So the dist gear was female style.
I had a thread a few years ago and I will try to find photos.
Old 07-26-2014, 12:56 AM   #11
Softpatch
Softpatch's Avatar
On my 67 C50 with a 327 the Dist Gear had a female slotted gear.
I've never heard or seen this always a slot in the oil pump drive and a blade in a dish on the end of the Dizzy shaft
Very intersting I looked at all my dizzy and non were diffrent 1960-1984
283,327,396, -350,454,
yes please if you could dig up pictures of this anomaly that would be great
....Sp
Old 07-26-2014, 09:50 AM   #12
colgad
colgad's Avatar
....Sp
I have looked and cannot find photo's I have another 67 C50 now and sometime next week Ill pull out the dissy and see if it is the same. If so Ill post the pics.
Old 07-26-2014, 11:31 AM   #13
mrolds88
One other thing. When you wire the HEI up, do not use the original power wire from the original distributor. They have resistance built in and don't deliver the full 12 volts. There are two ways to do this. First is to find a key on power slot on the fuse panel to hook the distributor power wire to, or using the original ignition power wire, run a relay to power the distributor. Like here.http://www.hoigto.com/tech/powerHEI.htm
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 07-28-2014, 10:47 PM   #14
jumpsoffrock
^Yes, I had read about that. In general, people advise to simply run a wire from the "unfused ign" port on the fuse panel, and run an inline fuse.
