Question for the guys with OEM 71-72 sport mirrors
I mounted a good quality aftermarket sport mirror on my passenger side in the factory location and i can't see anything with it. The mirror head doesn't turn far enough (it hits the base) to be usable.
My question is: is this just what you get in the aftermarket world or are the original (OEM) mirrors the same way? Thanks. |
Moderator
![]() Join Date: May 2007
Re: Question for the guys with OEM 71-72 sport mirrors
Sport mirrors suck for visibility, they are more of an accessory IMO
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Like Leddzepp said, they are more for looks than function. The originals aren't any better.
Agreed! I have never been able to adjust the passenger side in my 72' to see anything. Sadly they are the best looking mirrors though
It seems to me that I read that the passenger side mirror is mounted
a different distance from the edge of the door to correct this. Is that right? |
#6 | |
Carpe manana
![]() ![]() Join Date: Dec 2010
The RH mirror is installed sightly further back than the LH mirror IIRC.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
You need a pair of these new Soviet Micro Mirrors I've invented. Great visibility and almost undetectable.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
glad I read this I was going to get replacement sport mirror's for the daughter's truck guess we'll have to figure out something else then
1969 Chevy C10 2wd stepside longbox |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Nice mirrors and you have serious chrome on them.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Thanks! It was a stupid amount like $1000 because there are something like 26 individual pieces and there's a minimum charge per piece...
I know there were stainless West Coast JR mirrors and I have a vague memory of stainless SR mirrors on the larger trucks. But no chrome in the real world...
#12 | |
Guys, has anybody had visibility issues with the mirror arms that were used on the 67-68's with round mirror heads? I'm working on some arm designs and want to be sure to make any length/angle corrections if needed. I haven't heard of any issues with them, but want to make sure.
![]() Join Date: Sep 2013
Location: Sassafras. Victoria. The beautiful Mount Dandenong Ranges
I found exactly the same issues with the uselessness of the sports mirrors! Made more frustrating because I'm driving a left hooker on the left side of the road, I really NEED that right hand mirror. I was looking at the long 67-69 arms with a square mirror but can't find any down here. I found repop mirror heads from a 69 Holden and with a little ingenuity and a blob of JB Weld, fixed them to my original arms! Now I've got some practical mirrors that don't look too dramatically out of place with plenty of angle adjustment.
CLASSIC 1970 C20 WITH A RUMBLIN' V8. IT'S MY MID-LIFE CRISIS ONLY IT AIN'T A LITTLE RED SPORTS CAR OR A HARLEY! IF YOU'RE GUNNA SKATE ON THIN ICE, YOU MAY AS WELL TAP DANCE! |
#15 | |
#16 | |
#17 | |
#18 |
All the factory mirror set needs is a small change to the angle of the ball joint on the passenger mirror. Just a little more inward adjustment would be primo... until then, I'm just using a dumb-looking (but functional) convex mirror stuck on the passenger side sport mirror.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
#19 |
The arm could be re-designed, like you said but another idea would be move the mirror head mounting point to slightly off center, (more of the mirror to the outside of the arm) this may allow the mirror to rotate more before it contacts the arm. That's the problem, the mirror hits the arm before it's rotated enough to provide visibility. Slide the mounting point over half an inch and that may fix the issue.
#20 |
Is the problem it won't adjust far enough toward the door to see the rear quarter?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#21 |
Yes. The mirror contacts the arm before it moves far enough to be of any use.
#22 |
OK, at the risk of being booed off, I’ll offer this. If you can see your quarter panels, or close to it while seated your blind spots are not covered. To adjust the mirrors to get the blind spots covered, sit in driver’s seat and lean your head to the left until it just touches window, adjust mirror until you can just see the rear edge of the rear quarter. Then lean inboard about the same amount, should be about centered in the car, and adjust the passenger’s side mirror. When viewing all three mirrors you want the smallest amount of overlap possible. This method will all but eliminate the blind spots.
#23 |
I have found that if you rotate the mirror slightly clockwise the mirror will miss the arm and you can adjust it in enough to see a little bit, but its still limited as the mirror is flat and needs to be convex.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
#24 |
You would probably solve the issue by just using a convex mirror on the same product...would have to experiment with it to see.
#25 |
Still Learning
Does it do any good to reposition the mirror location forward or back to change the center of mirror rotation? I haven't drilled my doors for these mirrors yet but am close to doing it.
