Old 07-01-2014, 01:39 AM   #1
kev63rod
kev63rod's Avatar
02 6.0 4x4 trans, what fits?
so i just bought a 02 chevy cab and a half 4x4 6.0 auto 3500 dually. the motor is supposed to have issues but have not got to it yet. i know for a fact the trans is fried. what trans do i need to look for? 4l80e is what it has im sure, just not sure what years fit. i have a good 4l60e out of a 02 5.3 4x4 but it will not work, correct? would love to convert to manual but im sure that $$$$.
blessed are they that expect nothing, for they shall not be dissapointed
kev63rod is offline   Reply With Quote
Old 07-01-2014, 01:55 AM   #2
Gobuffalo
Gobuffalo's Avatar
Re: 02 6.0 4x4 trans, what fits?
The 4L80E can easily by bolted to a NP205 with a new adapter from Advanced Adapters (I've been told you can machine the factory adapter from a TH400 to NP205 quite easily). The 2 wheel drive trans is the easiest because you remove the tail shaft housing and replace it with the adapter and the tail shaft is long enough. You would want to use the NP205 from behind a TH400.
If you want to add super low range you get a Magnum Box from Off Road Design and it acts as the adapter between the 4L80E and NP205.
Gobuffalo is offline   Reply With Quote
Old 07-01-2014, 09:14 AM   #3
truckdude239
truckdude239's Avatar
check teh trans first if it has 2 speed sensors its the 4l80e if only 1 spped sensor itss the 4l60e, i've seen them both ebhind the 6.0
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 07-02-2014, 01:26 AM   #4
kev63rod
kev63rod's Avatar
so any idea where i could find the speed sensors at? pretty sure its an 80. has a hole up high on the drivers side that i believe should have been a speed sensor and i think it has one behind the big grey plug on the lower rear drivers side. so would a 60 work behind it with the same computer?
Old 07-02-2014, 08:54 AM   #5
95 S_Trucker
95 S_Trucker's Avatar
The only way you could get a 4l60e behind a 6.0 was in a Yukon denali or a vortec maxx truck.
Its a 3500 dually. There is no way it has a 4l60e. You want to look for a 4l80e. I'm not sure on the year range that you would be looking for.
95 S_Trucker is offline   Reply With Quote
