07-02-2014, 05:42 PM | #1 |
New trim fell off
How would you go about fixing this? Apparently 3M's adhesive for this trim ain't so great. I don't get a lot of time to work on the truck, and for the most part it sits in the garage. I am fixing it up a good bit before I start driving it on a fairly regular basis. So I hadn't gone in there in about 3 weeks. But then I finally go in, to find that the last bit of work I had done, has come undone. You can see the trim just laying there on the ground next to the truck where it fell off. Rather irritating.
So what should I use to fix the trim to the truck more permanently? Contact cement? And what is the best method of keeping it pressed up against the truck while it dries? Plus the old adhesive creates a lump in between the surface of the trim and the surface of the truck. Last edited by Skunksmash; 07-02-2014 at 06:03 PM. |
07-02-2014, 05:54 PM | #2 |
Re: New trim fell off
I'll bet you could contact a local body shop and they could tell you what they use. That's what I would try to do. GTT
GoTennTitans 1987 GMC Sierra 1990 GMC Sierra (stolen) 2003 Chevy Silverado |
07-02-2014, 06:40 PM | #3 |
What Hump?
I had to use double sided tape to get mine to stay. Also run masking tape diagonally across about every six inches.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 Last edited by Eyegore; 07-02-2014 at 06:46 PM. |
07-02-2014, 07:03 PM | #4 |
07-02-2014, 07:18 PM | #5 |
Hahaha cant help but I wish mine would all fall off!
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
07-02-2014, 07:53 PM | #6 |
I've only ever used 3M, it's very high quality. Biggest thing is to remove absolutely ALL dirt and wax with an adhesion promoter. If you don't use that, the best adhesive in the world won't work.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
07-02-2014, 08:00 PM | #7 |
What Hump?
What he said!!!!!
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
07-02-2014, 08:04 PM | #8 |
Parts and more parts
This answer is going to complicate your life a little. Go down to the local auto parts store and purchase a roll of 3M double sided adhesive. It is not cheap, but you should get the right width for what you want to use it for. NOW, remove all of the old adhesive from the trim and the truck, clean the trim and the truck with an alcohol based product. Rubbing alcohol works great. Let that dry, then put the adhesive onto the trim. Finally put the trim on the truck where it belongs. 3M has been dong this for years and if you go to a body shop, they will whip out their 3M adhesive and do the job, while charging you for the labor. I keep this stuff in my shop all of the time and the only time it gives problems, is when the surfaces are not cleaned well.
Frank |
07-02-2014, 08:11 PM | #9 |
I have never had that problem with 3M. Poor surface prep would be my guess but, I suppose it is possible you got a bad batch.
07-02-2014, 10:10 PM | #10 |
What Hump?
I looks as if he used the sticky on the back of the trim. I just went to home depot for the double sided tape I used 1/2 inch on both top and bottom of the trim it stayed on even in 115 degree tempatures.
07-03-2014, 11:29 AM | #11 | |
Plus, after sticking it on I used a roller from Momma's kitchen to apply quite a bit of force to wet out the adhesive. Been five years and they have all stayed on through all types of weather. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-03-2014, 01:00 PM | #12 |
I guess it must have been poor surface prep. All I did was wash it with water thoroughly, and then dry it. Then let it dry on its own for several hours.
Should have used alcohol or acetone or something. But I was questioning the adhesive of that 3M tape that comes on there. Because I got the trim from the parts store and the package looked like it had been there for years. All faded out and scuffed up and looking like it had been moved around a lot. Perhaps the 3M tape has a shelf life of some kind? Either way now I have to fix the mistake now. |
07-03-2014, 01:25 PM | #13 |
Use the 3M with the red backing and stick to alcohol. Don't use acetone, you will be sorry.
'86 Chevy K10 SWB Custom Deluxe 4x4 '94 Chevy Corvette '07 Ford Mustang '08 Lexus LS 460 |
07-03-2014, 02:01 PM | #14 | |
07-08-2014, 07:39 AM | #15 | |
K
07-08-2014, 10:53 AM | #16 |
What Hump?
I forgot to mention that when mine fell off I sent a letter to the company and they sent more trim back free of charge.
07-08-2014, 11:43 AM | #17 |
I usually let the tree limbs rip my trim off....lol.
