07-01-2014, 04:00 PM | #1 |
No brake fluid
I torn my blazer apart last year and I just got the brake system back together. I get fluid to my rear brakes but I am not getting any fluid out of my front cylinder. I need help
07-01-2014, 07:18 PM | #2 |
Re: No brake fluid
Did you bench bleed the master?
07-01-2014, 09:27 PM | #3 |
Re: No brake fluid
Did you set up the proportioning valve for bleeding as outlined in the service manual?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
07-01-2014, 10:11 PM | #4 |
Re: No brake fluid
Don't I need fluid to start coming out first before I remove the air with a nench bleed?
07-01-2014, 10:12 PM | #5 |
Re: No brake fluid
And no on the prop valve. How does one do that
07-02-2014, 08:55 AM | #6 |
Re: No brake fluid
No that is what the bench bleed is for. on all the new ones I have done the master comes with plugs you put in the outlets then hold or mount the master in a vice then push the "plunger" in several times getting the air out of the master before you install.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
07-03-2014, 01:03 AM | #7 |
Re: No brake fluid
Master was rusted and pitted. New master and found out my prop valve is rusted and seized in the front. Man I'm getting tired of buying parts I already own. Anyone know a good adjustable prop valve that will bolt up using existing hardware.
Tags |
brakes, fluid, front, master |
