Old 07-03-2014, 11:02 PM   #1
66Submarine
66Submarine's Avatar
Talking New engine! $400 6.0 LS...
Saw this on craigslist today and picked it up; iron block/aluminum head 6.0L LS out of a van with only 90,000 on the clock. Mine for all of $400.
Should be a fun little engine for not a lot of money! Going to be somewhat of a departure from the short winded and not overly powerful little 250 six in there now...
(Not sure when I'll throw it in yet; still need to come up with a harness for the EFI and a couple other things.)
More later...
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 07-03-2014, 11:04 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: New engine! $400 6.0 LS...
Sounds like a good deal!
Old 07-04-2014, 01:51 AM   #3
scuderia
scuderia's Avatar
Damn, I thought I did well getting the 292 and sm465 for $500, you win
Nice score.
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 07-04-2014, 07:15 AM   #4
bj383ss
bj383ss's Avatar
WOW! An LS for only $400. I need to keep my eyes pealed.
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 07-05-2014, 12:25 AM   #5
Captainfab
60-66 Nut
Yeah that is a good deal. Around here that engine would be at least $1400.
Old 07-05-2014, 07:56 AM   #6
66LSx
66LSx's Avatar
just think... your going to have nearly x10 invested in supporting the engine than the engine itself
(transmission, mounts,crossmember, harness, fuel pump, intake, o2 sensors, gauges etc)
But there so much fun!
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 07-05-2014, 10:16 AM   #7
joesscamaro
That's a killer deal...good find!
joesscamaro is offline   Reply With Quote
Old 07-05-2014, 10:57 AM   #8
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
That's a great deal there. Should be a fun build. All these cheap (in price) LS engines sure make it hard to sale an old school big block now a days. Can't wait to follow your install.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 07-05-2014, 04:43 PM   #9
66Submarine
I thought you guys might like it. $400 was certainly a deal on one of these!
BTW, this is going to be a super low $$$ project. I'm going to use all the stock EFI stuff and use part of a reprogrammed stock(junkyard) harness to control it. I need to come up with a little bit of (mostly junkyard) stuff, but it shouldn't cost much. I think it's going to be a really fun project!
Yeah Jim, these have pretty much killed the old hotrod SBC/BBC's for people who know anything about them. These things are really cool...
Old 07-05-2014, 04:52 PM   #10
66LSx
66LSx's Avatar
Things you'll have to decide on...
Drive by Wire? (then you need the matching pedal and TAC module for your ECM)
Is your current EFI fuel pump capable of supplying the 58psi for the LS?
Tank location (in cab may get noisey with the fuel pump)
transmission your going to use?
then driveshaft and new U-joints since its a 6.0 and you'll break the 1310's potentially.
Oh the fun
there so many more thing... but just stuff for you to chew on
1966 C10 SWB Fleet
Old 07-05-2014, 05:24 PM   #11
MalibuSSwagon
Harness is easy, I picked up the complete harness and ECU for $60 from a local and stripped it down in a few hours with direction from LT1swap.com
$400 is a steal!
MalibuSSwagon is offline   Reply With Quote
Old 07-05-2014, 06:19 PM   #12
66Submarine
Oh the fun
No drive by wire BS--cable throttle.
Fuel pump will very likely just be one taken from a late model truck/car that is suitable for the LS.
Not sure about tank location; already thought an underbed (or something) tank might be neat. Not a big deal if I go that route.
The OE SM420 HD truck four speed that's in there will stay for now. NV4500 or similar would be nice, but I need to find one first. SM420 should have no trouble at all with semi-sane driving, though; the NV4500 is pretty much just for the OD and potentially slicker shifting (If I was drag racing I'd put a TH400+loose converter in it--it's a DD/work truck.).
Following that; it's actually a one ton truck (C30), so it has an HD truck driveshaft with the HD carrier bearing and 1350 u-joints from GM; no problems there.
Old 07-05-2014, 07:37 PM   #13
hotrod66
hotrod66's Avatar
so are u going to putt it in your step side that you just put the 6 in?
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 07-05-2014, 08:48 PM   #14
66Submarine
That's the idea for now. It's the truck I'm currently driving/using (no sense repowering a truck that's sitting!), and the 6.0 should also make pulling trailers and merging onto busy highways really nice.
(The 250 that's in it now was actually supposed to be an engine to run until I put the new 292 in it, BTW.)
Not sure if I'll leave the 6.0 in this truck and use the rebuilt 292 in a half ton or what. I actually have a pretty good mountain of engines I'd like to put in something at some point! This probably won't be the last time I have an engine on a hook.
Old 07-08-2014, 03:50 PM   #15
blazer-k5
blazer-k5's Avatar
Good find man. You will be pulling that trailer around in no time with it.
No trees were killed to send this note but a large number of electrons were terribly inconvenienced.
AKA. RABIDJOE... if you have to ask you prob don't want to know. Ive had my shots *dont worry*
1960 235 4SPD C30
blazer-k5 is offline   Reply With Quote
Old 07-08-2014, 04:20 PM   #16
ssxty8
Thumbs up Re: New engine! $400 6.0 LS...
Same here on the above, or even worst. That would look really GREAT on my project! Dreaming don't cost a dime.
Good luck, and please post all your build details, so if budget permits, one can follow that mostly stock swap route.
EXITO!!!!
ssxty8 is offline   Reply With Quote
Old 07-08-2014, 10:02 PM   #17
66Submarine
Yeah, I'm going to document the swap real well for others looking to do the same.
BTW, I got it unloaded the other day. (Sitting beside the 283 that came out of the truck that I still have sitting there. )
Soon...
