Old 07-04-2014, 08:40 PM   #1
86c20
86c20's Avatar
Edl 1409
can i use this carb on my c20? willl it have the port in back for the brakes? also this is on a egr motor does any one know how much for a spacer i will need to clear the egr? thanks
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 07-04-2014, 10:19 PM   #2
geezer#99
geezer#99's Avatar
Re: Edl 1409
Why that carb?
All the vacuum ports are plugged on it, so no egr, no vac advance, no power brakes and no pcv.
Get a 1406 instead.
Old 07-05-2014, 05:43 AM   #3
86c20
86c20's Avatar
Re: Edl 1409
well i have a chance to get it new for 200 bucks. but thats what i was wondering about was all the vac. all i need for vac is brakes and dizzy and the brakes i can do with out as i can put it on my hydro bost truck. thanks
Old 07-05-2014, 08:53 AM   #4
geezer#99
geezer#99's Avatar
Re: Edl 1409
Sometimes the price isn't right or cheaper.
Cost you about 100 more for the better carb.
http://www.summitracing.com/int/part...1406/overview/
Old 07-05-2014, 04:48 PM   #5
86c20
86c20's Avatar
Re: Edl 1409
damnit. ok thanks guys
Old 07-06-2014, 12:28 PM   #6
cadillac_al
Re: Edl 1409
I've got a 1409 on my truck with electric choke. I just get my manifold vacuum off the manifold. It is jetted richer than the 1406. It sure runs a lot better than my old out of the box 1406's. I am going to jet my 1406's just like my 1409. I don't think the lack of vacuum ports on the 1409 is that big a deal on an old Chev.
I can't even get a Quadrajet to outperform my 1409 yet. I'm still working on it because the Quadrajet has a much better automatic choke system.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 07-06-2014, 02:05 PM   #7
naphtali5725
naphtali5725's Avatar
Re: Edl 1409
the right Quadrajet (800cfm) even the 750 will outperform that carb easily, and has electric choke... most stock QJets for a particular vehicle are jetted/rodded pretty close most of the time, unless it's been remanufactured...
keep tuning that QJet , or have a good QJet builder do it...
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 07-06-2014, 07:05 PM   #8
86c20
86c20's Avatar
Re: Edl 1409
do you know of any good rebuilders? i have been running it 8 years no problem and now i think the flot sticks oopen and closed. i am not looking for any power but will take what i can get lol. are the qjets really a 750+? that seems really big for a 350.
also i thought dizzy was port vac? not manifold.
Old 07-06-2014, 07:12 PM   #9
naphtali5725
Re: Edl 1409
depends on your application on whether you should use ported or manifold vacuum source...
the QJet came in 750 and 800 cfm... and it will only flow the amount of air that the engine needs...
Lars Grismund v8fastcars@msn.com is who I used for a basic rebuild, and tune, he's well known in the corvette circles
Mark Smith @ www.mjproformance.com is a good QJet guy
Cliff Ruggles basically wrote the book on QJets... but probably 6+months wait time...
My build thread...
Disabled Veteran
Old 07-06-2014, 07:53 PM   #10
86c20
86c20's Avatar
Re: Edl 1409
the app is a daily driver the is 5200lbs with a stock motor that tows once a month thats maybe 10k?? whats that tell you??
Old 07-06-2014, 08:25 PM   #11
naphtali5725
Re: Edl 1409
maybe this will help you.... it's long, but informative... good luck with your tune!
This was the post I found on a MOPAR forum during a google search.
This was written by a former GM engineer as a response to a similar question on a Corvette board:
As many of you are aware, timing and vacuum advance is one of my favorite subjects, as I was involved in the development of some of those systems in my GM days and I understand it. Many people don't, as there has been very little written about it anywhere that makes sense, and as a result, a lot of folks are under the misunderstanding that vacuum advance somehow compromises performance. Nothing could be further from the truth. I finally sat down the other day and wrote up a primer on the subject, with the objective of helping more folks to understand vacuum advance and how it works together with initial timing and centrifugal advance to optimize all-around operation and performance. I have this as a Word document if anyone wants it sent to them - I've cut-and-pasted it here; it's long, but hopefully it's also informative.
TIMING AND VACUUM ADVANCE 101
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
My build thread...
Disabled Veteran
Old 07-06-2014, 08:52 PM   #12
Just call me Sean
Just call me Sean's Avatar
Re: Edl 1409
Thank you for that. Very interesting. So the carb he wants to use can work for him if he so desires.
Just call me Sean is offline   Reply With Quote
Old 07-06-2014, 09:06 PM   #13
naphtali5725
Re: Edl 1409
for a mild performance daily driver... and as always, there are a gazillion instances where trial and error will be needed depending on application... engine size, tranny, diff, cam size/duration, blown, turbo'd, street, street/strip, full race etc. etc. etc...
My build thread...
Disabled Veteran
Old 07-07-2014, 09:09 AM   #14
geezer#99
geezer#99's Avatar
Re: Edl 1409
Thanks for posting that naphtali5725.
It follows the basic #1 rule.
Timing first, carb second!!
Old 07-07-2014, 09:11 AM   #15
naphtali5725
Re: Edl 1409
yw, that's basically the right rule... can't burn fuel without timing
how is BC this time of year? day temps/night temps? been looking to move to Kamloops some day, any info? stay away? LOL
My build thread...
Disabled Veteran
Old 07-07-2014, 09:50 AM   #16
geezer#99
geezer#99's Avatar
Re: Edl 1409
It's been a cool wet june and now into july. More rain than normal. That's here on the Island. Been better elsewhere. Search google for the Loops weather history.
http://www.myweather2.com/City-Town/...e-profile.aspx
Nice city, nice countryside. Lots of hotrodders there and down the Okanogan.
Our apoligies to 86c20 for jackin' his thread a bit!!
Old 07-07-2014, 10:07 AM   #17
naphtali5725
Re: Edl 1409
thnx... yeah, sorry about that, i'll pm next time
My build thread...
Disabled Veteran
Old 07-07-2014, 10:55 PM   #18
86c20
86c20's Avatar
Re: Edl 1409
indont mind at all some times its a nice brake in the read lol
Old 07-08-2014, 07:25 AM   #19
86c20
86c20's Avatar
Re: Edl 1409
well now that i have reread this a few times i have a good understanding that all this crap is just that and for a goor relible runner go back to the 60's way with carbs little vacc no egr no cat no bs and tune it in.
so manifoild it is then.
now let me tell you guys whats going on with my truck i might have jumped the gun with thinking carb (glad i did just for the timing read) under real light load she runs great get in to second gear nail it get to the top end she breaks up and wont run for crap. let off go into 3rd some times she is fine other still crap. cold hot dont seem to matter. changed filter was little pluged not bad for 8 years of nothing. going to try a coil next and plugs as they are on the oldeer side.........not saying how hold tho lol but soometimes you hit the gas adn it feels like there is no fuel there just a lite dead pedle. anything???
Old 07-08-2014, 08:41 AM   #20
geezer#99
geezer#99's Avatar
Re: Edl 1409
Now we need more info on your set up and some pics.
What motor?
What carb and intake?
What distributor?
Did I mention pics?
Pics help a bunch!!
Old 07-08-2014, 07:03 PM   #21
86c20
86c20's Avatar
Re: Edl 1409
its a crate 350 from gm with all stock parts and i mean stok but the dizz is from a 80 350
Old 07-08-2014, 07:14 PM   #22
geezer#99
geezer#99's Avatar
Re: Edl 1409
So absolutely stock!
Single stock exhaust, stock cam, stock quadrajet, stock intake, stock air cleaner.
A pic helps a bunch!
Do you have a link to the motor so we can determine your tune?
Old 07-08-2014, 07:24 PM   #23
86c20
86c20's Avatar
Re: Edl 1409
the only thing not stock is the exhaust and that is cut after the stock cat. no muffler. everything else is stock stock stock think its a 260hp crate cam carb air cleaner intake everything stock................for now lol
will get pics tonight i hope
Old 07-28-2014, 10:26 PM   #24
86c20
86c20's Avatar
Re: Edl 1409
ok update. i have found the problem with my truck. after doing the tune up plugs wires cap rotor coil. i found no improvement with it at all. so after much fighting i checked my fuel pump and found only 3psi running and at wide open 1.5 not even close to keep up at all. so new stock pump and life is good.................for now lol.
thanks for all the info that was given really did help understand alot of things
Old 07-28-2014, 11:02 PM   #25
naphtali5725
Re: Edl 1409
glad you got the real issue resolved...
what carb did you go with?
good luck
My build thread...
Disabled Veteran
