Old 07-04-2014, 10:39 PM   #1
KIC
1960 GMC Burb
KIC's Avatar
New Paint - Rust issue
So I have been on a slow track on painting my 1960 GMC Burb. We painted the top and the hood several years ago. Thought we prepped it pretty well. While sanding and taping for more paint I noticed a rust issue in the front hood seem.
What should I do to correct and stop this problem ?
1960 GMC Suburban
1/2 ton V-6
2nd generation original owner
60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban
60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs
2003 Tahoe LT
KIC is offline   Reply With Quote
Old 07-04-2014, 11:11 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: New Paint - Rust issue
Problem is, the rust was still in the seam and even though it was painted and cleared, air can still get to it from the backside of the seam (inside the hood). Rust never sleeps.
At this point, you'll need to strip the paint at the seams and use some type of rust converter (like Rust Mort), then repaint it. You should also paint from the back side of the hood, to help seal it up.
Good luck.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-05-2014, 10:58 AM   #3
AcampoDave
AcampoDave's Avatar
You can clean the stains off with polishing compound, but like Mike said, the problem is inside the seam and until that is resolved the stains will return.
AcampoDave is offline   Reply With Quote
Old 07-05-2014, 04:17 PM   #4
jbgroby
jbgroby's Avatar
Use seam sealer once you have her really clean.
Every seam on my truck is sealed.
jbgroby is offline   Reply With Quote
