Old 07-06-2014, 02:02 PM   #1
Chevy_422
flywheel clutch question. help please!
i have a 1967 c10 witha inline 6 witha 3spd and its seen its day.
buring oil and i know what that means, i have an original 1965 283 v8 with about 60,000 miles on it. will the 283 bolt right up to my manual 3spd on the colum?? thank yall
Chevy_422 is offline   Reply With Quote
Old 07-06-2014, 03:52 PM   #2
Wrenchbender Ret
Re: flywheel clutch question. help please!
Yes. It will bolt up to the 6 cyl. bell housing.
Wrenchbender Ret is offline   Reply With Quote
Old 07-06-2014, 04:08 PM   #3
buz48
I have a 70 C/10 and I had to get different perches for the motor mounts when I put my 400 SB in otherwise your motor will set against the the fire wall
Buz48
buz48 is offline   Reply With Quote
Old 07-06-2014, 04:43 PM   #4
Old Truck Man
Old Truck Man's Avatar
all the six cyl parts like the starter flywheel clutch & bellhousing will fit a v8. I installed a 350 in a 67 GMC and the 6 cyl side mounts fit the V8 the only change I did was install a larger radiator the had three rows of cores. Unless you some how move the rear engine mounts & crossmember the V8 engine wont set any farther back than the six cyl does. on my 67 GMC and every 60 thru 66 standard shift truck ive ever seen there are two bolts that go through the rear mounts and thread into ears on each side of the bellhousing. and the rear crossmember is riveted into place.
Old Truck Man is offline   Reply With Quote
Old 07-06-2014, 11:52 PM   #5
Chevy_422
so i should be fine with the flywheel and clutch bolting up strait to the 3 spd tranny? thanks such a big help
let me be more detailed, sorry
283 bolt right up to the 3 spd
Old 07-07-2014, 10:47 AM   #6
old Chevy guy
old Chevy guy's Avatar
yes, your clutch pressure plate ,flywheel , bell housing and 3 speed from your 6 cylinder will bolt to your 283.
old Chevy guy is offline   Reply With Quote
Old 07-07-2014, 11:10 AM   #7
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
yep it will bolt right up ! That's the great thing about 1955 thru 1974 chevy stuff everything will fit ,m love those years !
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
