Old 07-08-2014, 08:52 PM   #1
Jurassic-1
Jurassic-1's Avatar
1965 SWB 4x4 Production #s
Does anyone know how many 1964-1966 Short bed 4x4 trucks were built. A friend of mine found one about 3 weeks ago and picked it up at a small car lot. He paid $5000 for it. It seems to have 95000 original miles. The body has some rust but the cab is very nice and waxed up the patina is great. He wants to replace the sheet metal as he finds it. It runs great with a 292 engine. Everything works except the shifter has no real neutral. Possibly the detent spring is bad. I was unsure of the production since i have only seen a few short bed 4x4s.
Jurassic-1 is offline   Reply With Quote
Old 07-08-2014, 09:20 PM   #2
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Re: 1965 SWB 4x4 Production #s
1964 = ?
1965 = 633
1966 = 678
These are numbers that were posted on another website. 1966 unmolested worth the most since this was the last year for the body style.
66Gilbert is offline   Reply With Quote
Old 07-08-2014, 09:27 PM   #3
Jurassic-1
Jurassic-1's Avatar
Wow these are low numbers. He is wanting to eventually do a ground up on it. The frame is very nice and everything is still unmolested.Thanks for the info.
Old 07-08-2014, 09:32 PM   #4
66Gilbert
66Gilbert's Avatar
Need to see some pictures of it. Also just noticed that we are almost neighbors.
Old 07-08-2014, 09:37 PM   #5
Jurassic-1
Jurassic-1's Avatar
I will get some. Do you know how many long beds were made?
Old 07-08-2014, 09:43 PM   #6
66Gilbert
66Gilbert's Avatar
Production numbers are only shown for 1965 and 1966. (K10)= Short Bed 4x4 (K15) = Long Bed 4x4. Here is a link http://reocities.com/MotorCity/speed...roduction1.htm
Old 07-08-2014, 11:39 PM   #7
Jurassic-1
Jurassic-1's Avatar
Thanks. He has the stepside but they are still very low #s. What truck do you have?
Old 07-09-2014, 12:59 AM   #8
66Gilbert
66Gilbert's Avatar
My truck is a 1966 K10 Short Bed Fleet Side.
Old 07-09-2014, 10:18 AM   #9
Jurassic-1
Jurassic-1's Avatar
Very nice.
Old 07-14-2014, 12:47 PM   #10
Jurassic-1
Jurassic-1's Avatar
Here are a few pics of Chris truck.
Old 07-14-2014, 12:48 PM   #11
Jurassic-1
Jurassic-1's Avatar
Here are a few more
Old 07-14-2014, 02:16 PM   #12
RANDY COX
RANDY COX's Avatar
KOOL I like that truck love them steppers too...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 07-14-2014, 08:18 PM   #13
Jimal
Jimal's Avatar
I have a '65 K10 short step (or at least I think it's supposed to be a short step) and I'm shocked by the low numbers, if they are in fact accurate. Mine is such a hodgepodge at this point that it isn't a restoration candidate.
Jimal is offline   Reply With Quote
Old 07-15-2014, 12:05 PM   #14
Jurassic-1
Jurassic-1's Avatar
Chris is building a short wide 64 pickup show quality. He happened upon this truck and plans to just gather parts and clean it up then some day restore it. We have done 1967-72 trucks since 1978 and just recently decided to tackle these earlier trucks. They are a bit harder to get information .
Old 07-15-2014, 01:53 PM   #15
Keith Seymore
Keith Seymore's Avatar
My dad built the die to make that grille. It was tricky to keep running because those rectangular punches would break off resulting in running junk parts until somebody noticed.
He earned enough money in "Suggestion Awards" on that program to purchase a brand new '69 GMC stepper.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 07-15-2014, 02:00 PM   #16
bhc41051
bhc41051's Avatar
Jimal see if the Serial Number of the cab matches the Serial Number of your frame, if the S/N matches that will tell you if the cab is original to the frame. The S/N will tell you the correct year,1/2 or 3/4 ton, 2 or 4 wheel drive, long or short wheelbase, cab and pickup box or cab and chassis and the plant where the truck was manufactured take a look at the GVW data plate that will tell you the color and if it has standard trim or custom. This information should give you some direction for your restoration.
bhc41051 is offline   Reply With Quote
Old 07-15-2014, 03:20 PM   #17
Jimal
Jimal's Avatar
I haven't looked for the VIN on the frame, but I know it won't match since the cab (which has the number the truck has been registered under for the past 30 or so years) came from a 3/4 ton 2wd long bed. The truck is a mutt, which makes my life easier.
Old 07-15-2014, 06:06 PM   #18
Jimal
Jimal's Avatar
This is what I found on the frame rail in the location indicated in the FAQ, 6T. Could be a GMC frame. Who knows? I'm not too worried about it.
