Old 07-09-2014, 07:02 AM   #1
bikernut
bikernut's Avatar
Trans Lines
I have a 2003 3500 dually with a 6.0 engine and a 4L80E trans. the cooler lines are leaking badly and I am trying to replace them but so far I have gotten 2 sets from 2 different manufacturers and they are not even close to fitting. Mine have the trans end the screw into the case and the replacement ones don't they just have a rubber or plastic washer type affair and no ends that screw into the case and they don't have the same bends to go to the front radiator and cooler. I need help!!!!
thanks
2020 GMC Acadia Denali (Maroon)
2003 GMC 3500 4X4 Dually Dump (Red)
2007 KZ 41KG Toy Hauler (White with stripes)
2015 Harley FLHTCUTG Trike ( Maroon)
1995 Harley FLT (2 tone Red)
1992 Chevy S-10 4x4 Blazer (Dark Red)
bikernut is offline   Reply With Quote
Old 07-09-2014, 11:34 AM   #2
Mr-Jack
Beer Drink'n Knuckle Dragger
Mr-Jack's Avatar
Re: Trans Lines
You should contact a local shop that makes custom lines. I had to have some brake lines made for my 67 and took the old ones down. they matched everything to my specs, and they did it in about 30 minutes
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US
- 67 GMC Long-Wide 350/SM420
My BACON Wrapped Meatloaf Recipe
Mr-Jack is offline   Reply With Quote
Old 07-10-2014, 10:26 PM   #3
1FastBrick
Re: Trans Lines
Factory transmission lines don't screw in on these trucks, they push into the fitting and have a wire clip to retain them in the fitting. There is a plastic cap that goes over it to hold the clip. I believe the rear fitting has an O ring between the fitting and the case.
These are the part numbers I came up with for an 03 3500 with 4L80E. Double check with a dealer before ordering to verify they fit your application. If they are correct, you can get both lines new for around $50
15812030
15812049
These images should give you an idea of how they fit together as well as what the clip would look like once pulled out. The plastic cover will pull back to expose the clip in the fitting.
[/URL]
1FastBrick is offline   Reply With Quote
Old 07-11-2014, 04:57 AM   #4
bikernut
bikernut's Avatar
Re: Trans Lines
thanks I will check it out, this is what mine look like
Old 07-13-2014, 06:07 PM   #5
1FastBrick
Re: Trans Lines
Hmmm, That's interesting. I have not seen that on these new trucks.
Maybe check with the dealer and see what they come up with. Maybe its something specific to a dually chassis.
Old 07-13-2014, 06:16 PM   #6
bikernut
bikernut's Avatar
Re: Trans Lines
we are thinking maybe some one changed them out when they started leaking before I purchased it
Old 07-13-2014, 06:20 PM   #7
1FastBrick
Re: Trans Lines
Entirely possible. Maybe thats why nothing you ordered fit.
