Old 07-09-2014, 04:07 PM   #1
chevyc10lover
´67 weekend driver
im almost ready to start the frame off in my 67.
ive had it for 6 years most of this time in storage..
the only thing i ve done is put a 5.7 vortec /4l60 is mounted but not wired.
i already have a painless wiring arness that i bought last year.
i bougth the engine, transmission, diff. tank. radiator from the 1999 donor truck.
plan is to use the new diff it has disc brakes, i hope i can narrow this since it is wider than the stock rear diff. any one has done this diff swap??
i will post pictures later.
i hope i can start next week.
chevyc10lover is offline   Reply With Quote
Old 07-09-2014, 04:21 PM   #2
joey8383
joey8383's Avatar
Re: ´67 weekend driver
Let's see some pics! Your plan sounds similar to a few really nice builds going on here now. Tons of info here but I have never personally heard of doing the late model rear end swap. Anything is possible just got to weigh out if it's worth the time, money and effort. Looking forward to seeing pics.
joey8383 is offline   Reply With Quote
Old 07-09-2014, 06:31 PM   #3
chevyc10lover
pics of my truck..
just removed seat, gas tank, and carpet,
Old 07-09-2014, 06:41 PM   #4
chevyc10lover
thanks!
that is what im thinking if it is better to use the "new" dif, involves a lot of work.
narrow, cut and respline axle, and bore them to 5 on 5". but it already have disc brakes
on the other hand i have to change ring and pinion since it is really slow.. then change bolt pattern on axles and make it disc brake..
Old 07-09-2014, 06:51 PM   #5
chevyc10lover
interior pics..
Old 07-10-2014, 10:05 AM   #6
joey8383
joey8383's Avatar
Might be cheaper/easier to find a 71-72 12 bolt rear end and just slap disk brakes on it. Looks like a solid platform to start with. What's your build plans?
Old 07-10-2014, 08:29 PM   #7
chevyc10lover
that is a good option ill look for it at the junk yard.
my plan is to do a complete frame off resto mod.
sand blast bare frame and suspension parts, then spray some black epoxy finish.
some parts i already have are:
mcgauhgys drop spindles 2 1/2"
front disc rotors from power slot.
Eibach Front drop springs 1"
mc gaughys rear drop springs 4"
painless efi arness for vortec 5.7/4l60e
cab corner patch..
18" Chrome wheels
get sheet metal to bare metal and try to do as more as posible the body work by myself.
exterior no mods. i like the ´67
interior i would like some new style seats good sound sistem.
day dreaming....
Old 07-11-2014, 08:20 AM   #8
mcbassin
Still Learning
mcbassin's Avatar
Pretty solid starting point you have there.
Old 07-11-2014, 08:29 AM   #9
nlped
nlped's Avatar
I guess the bed has been swapped since it has marker lights? Looks like a pretty solid starting point for sure. How wide is the new model rearend? I put a '73 up 2wd rearend under my coil spring '70 model...just had to cut the leaf spring pads off and weld on the appropriate trailing arm pads...the rearend is a bit wider than the 2 offered in the 67-72 trucks, but hasn't given me any issue...I just swapped the drums to disc.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-11-2014, 06:21 PM   #10
chevyc10lover
thanks.
yes the bed was swapped because it had a Mexican made one that i didnt liked because of the wheel arc was like a 65 bed...
the "new" rear end is a 1999 silverado but is 6 " wider than the stock one..
i have to measure how it fits with the wheels ill use on the truck. if there is enough clearance for tires would be ok..
Old 07-22-2014, 11:52 AM   #11
chevyc10lover
now she has a house!
lets start disassemble...
anybody know if using mcgaughys drop spindles change the width?
Old 07-22-2014, 01:30 PM   #12
mcbassin
Still Learning
mcbassin's Avatar
Warning: they come apart way faster than they go together.(ask me how I know).
Not sure about the drop spindles? check with lolife99 he knows everything there is to know about these truck suspensions.
Old 07-22-2014, 03:12 PM   #13
chevyc10lover
im shure it is faster to come apart...
i hope i can finish the Truck in a year...or less...
Old 07-23-2014, 01:18 AM   #14
Mr.chivo
Nice project! Do you have any pictures of the old Mexican bed? Is your truck a true Latin American model? Do you have any pictures of your gauge cluster?
Mr.chivo is offline   Reply With Quote
Old 07-30-2014, 03:40 PM   #15
chevyc10lover
cant find photos of the bed it seems to be that the bed was made in mex and the cab is same as usa made, look at the pics in the post to see the dash.
Old 07-30-2014, 08:05 PM   #16
chevyc10lover
i just found the motor was mounted awkward
mounts where cut and a angle iron welded to it...
dont know if it was a clearance issue, but i think is best to order headers now so i can fit it before i paint the frame and now that a have loose bolts and nuts..
i think i should move the "custom" tranny bridge too..
any advice i can get to mount the engine would be nice.
Old 08-18-2014, 08:25 PM   #17
chevyc10lover
i just stripped the paint on a bed side, i think is good, no rust just some dents and holes from trim. hope the other side is same..
Old 08-18-2014, 08:33 PM   #18
chevyc10lover
Old 12-19-2014, 03:50 PM   #19
chevyc10lover
just started to disassemble and thought i have to replace cab corners and rockers, so i needed a mig welder, bougth a miller 211 and made a cart for it. another proyect.... but it will help on the build of the truck
http://67-72chevytrucks.com/vboard/a...1&d=1419018309
Old 03-28-2015, 03:38 PM   #20
chevyc10lover
after some time i finally started again working on the truck.
y removed one side of the front clip.
leave the other so i can install the drop spindles, and drop coils , crossdrilled front rotors and see how the tire and wheel combo fits..
http://67-72chevytrucks.com/vboard/a...tid=1383647&st
c=1&d=142756http://67-72chevytrucks.com/vboard/attachment.php?attachmentid=1383649&stc=1&d=14275699209920
some of the parts i got are: all Moog front suspension, total urethane bushings set,mcgauhgys spindles2.5" lower , front rotors,Eibach 2"lower Front coils, mcgahugys rear springs 4" lower. i got a used tire to check fitment before i order new tires. and a set of headers..
so i have a lot of work to do.
my plan is to install spindles, rotors and coils to check the stance.
then take out the cab and redo the engine & tranny mounts.
Old 03-28-2015, 04:22 PM   #21
chevyc10lover
i removed the old coils and replaced w the new eibach ones. removed front drums, put the new spindles, bearings and rotors so it is closer to the ground
18" wheel 275/55r18 tire. i like it!
Old 03-30-2015, 08:00 AM   #22
mcbassin
Still Learning
mcbassin's Avatar
Nice progress on your truck. Love the disc brake upgrade.
Old 03-30-2015, 02:39 PM   #23
chevyc10lover
removed the bed, and the wiring arness. next is to bolt the headers and check clerances and mount the engine and tranny properly.
Old 03-30-2015, 02:40 PM   #24
chevyc10lover
slowly but there is some progress..
Old 05-08-2015, 03:47 PM   #25
chevyc10lover
finally is almost bare frame.
